sneeky Posted January 2, 2015 Share Posted January 2, 2015 My dad took my car & accidentally put in E85. Can I run through this tank? Have not been able to siphon the gas out & I don't want to pay someone to dump the gas tank. Link to comment Share on other sites More sharing options...
covertrussian Posted January 2, 2015 Share Posted January 2, 2015 The real issue with E85 is, it's not friendly to traditional paper fuel filters and fuel lines. Alcohol traps moisture and moisture is not friendly on the paper fuel filter in the trunk. It also can cause rust in the tank and in the hardline fuel lines. Next issue is the tune, E85's stoichiometric ratio (9.8:1 AFR) is much lower then regular fuel (14.7:1 AFR), thus your stock tune will try to run it 5 points leaner, which means the motor wont be happy and will bog while cruising (same as trying to run 19.7:1 AFR's on gas). While E85 has better knock threshold due to better octane rating, it still will be very lean at full throttle, which is not good either. Honestly your best bet is to get under the car and fine the gas tank, there should be two drain holes for each section of the tank (it's split into two to allow for the rear driveshaft to fit). Then you really should consider replacing the fuel filter, it's around $80. On the bright side, your car probably has enough miles to need a new fuel filter anyway. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Redslaya Posted January 2, 2015 Share Posted January 2, 2015 Time for that e85 conversion you know you have been wanting to do. but in all seriousness listen to covertrussian Link to comment Share on other sites More sharing options...
Mike07LGT Posted January 2, 2015 Share Posted January 2, 2015 How do you accidentally put E85 into your car? Isn't it hard to find and more expensive then normal pump gas? 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Strizzy Posted January 2, 2015 Share Posted January 2, 2015 How do you accidentally put E85 into your car? Isn't it hard to find and more expensive then normal pump gas? E85 is pretty much everywhere around here. It's currently at $1.82/gal. My bad luck build Link to comment Share on other sites More sharing options...
MrTris Posted January 2, 2015 Share Posted January 2, 2015 How do you accidentally put E85 into your car? Isn't it hard to find and more expensive then normal pump gas? Depending on where OP lives, it might have been the cheapest option, and/or dad thought it was the 'sporty' gas. Whenever folks borrow my car, I leave explicit instructions with DOs and DON'Ts. Puts a stop to people borrowing your car pretty quickly. Link to comment Share on other sites More sharing options...
BigTDogg MA Posted January 2, 2015 Share Posted January 2, 2015 There is no E85 out here. Wish there was. It's near you Strizzy because UBIN corn country Link to comment Share on other sites More sharing options...
covertrussian Posted January 2, 2015 Share Posted January 2, 2015 Depending on where OP lives, it might have been the cheapest option, and/or dad thought it was the 'sporty' gas. Whenever folks borrow my car, I leave explicit instructions with DOs and DON'Ts. Puts a stop to people borrowing your car pretty quickly. I do the same, I tell them just let me fill it up and pay for the gas. But if you must, you must use Shell 93 only, must let the pump punch out twice only, must write down miles driven, and reset the trip odometer. That's with my turbo Nissans, Sadly I don't feel comfortable lending my Subaru's. Because then I had to add, make sure you check the oil week/100 miles, make sure not to floor it too much... 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
sneeky Posted January 3, 2015 Author Share Posted January 3, 2015 I'm in Denver. E85 is like regular gas here. The highest octane we have is 91. I think it's due to the dry climate and elevation. Link to comment Share on other sites More sharing options...
BoostSLUG Posted January 3, 2015 Share Posted January 3, 2015 I'm in Denver. E85 is like regular gas here. The highest octane we have is 91. I think it's due to the dry climate and elevation. ...what? E85 is still pretty rare in denver. My friends that run e85 have to calculate trips carefully so they never run out of fuel Link to comment Share on other sites More sharing options...
