testes1010 Posted November 6, 2008 Share Posted November 6, 2008 I'm Jeremy, same testes1010 on all the Suby forums. I recently sold my 2003 WRX, mod list and dyno chart link posted below. ENGINE/DRIVETRAIN: - ROMRaider/OpenECU reflash tuned by me - TurboXS Hyperflow Top Mount Intercooler w/ custom made splitter - Ultimate Racing EWG Uppipe ceramic coated by Crucial Racing w/ Tial 38mm EWG - HKS Downpipe ceramic coated by Crucial Racing w/ 3" Magnaflow race muffler & custom 3" SS piping - BPM XVR crossover pipe with port-matched & ceramic coated stock exhaust manifold, services supplied though Crucial Racing - Crucial Radiator Shroud - Ultimate Racing 785cc/min Cylinder Flow Matched Injectors - Deadbolt Zilla TD05H-20G-7cm^2 turbo - CoolingMist 150PSI Alky Injection (7gph nozzle @ the TB, 1.3gph pre-turbo, boost pressure switch activated.) - Hallman PRO MBC - Perrin Turbo Inlet Hose - Walbro Fuel Pump 255lph - XS Engineering CAI w/ GREEN™ filter - Mr. Josh's Lightened Crank Pulley - Autometer Gauges (Boost & EGT) - VDO TMIC exit IC temp gauge(currently disconnected) - STi Shoft throw shifter w/ Kartboy Shifter bushings - APS DualVent BPV - SPEC STG2 Clutch - ACT Streetlite Flywheel - STi Group N Tranny Mount - STi Group N Engine Mounts - SuperPro Steering Rack bushings SUSPENSION/BRAKING: - Hotchkis 25mm Competition Front / Rear Sway Bar/mounts & Rear End Links - Hotchkis Lowering Springs - KYB GR-2 Struts F&R - Porterfield Street Pads F&R - Group-A Front End links WHEELS / TIRES: - Duplicolor Gold Painted stockers - Falken ZE912 225/50/16 w/ 3-4k miles on them currently BODY / INTERIOR: - JDM STi Grill, hood scoop, side skirts, side markers - Debadged SUBARU - Koji'd Head lamps - 20% Tint - Innovate LM-1 WBO2 custom setup where stock clock was at. Dyno Graph, 50/50 Meth + 93 vs. 93 octane only, both are 24psig all the way to redline Why I'm here: I'm picking up a bone stock 2005 SWP LGT sedan 5MT w/ ~60k miles Sunday. This thread is to document my mods, tuning methods(since I do ALL my own tuning), and results of each stage of the process. So far I've ordered the following items: - Magnaflow Catback - Tuning Alliance TMIC - Hallman Pro MBC(I don't want to hear it, a properly tuned car with a MBC will NOT blow your engine) - All Weather floor mats(to get in on the VF52 giveaway) - I'm picking up a uppipe from a buddy - Bidding on a Invidia DP locally thru EBay As I said I do all my own tuning using ECUFlash and Romraider. As you could see with my 2.0L WRX I was not afraid to push the envelope. I'll keep you posted. Link to comment Share on other sites More sharing options...
HansGT Posted November 6, 2008 Share Posted November 6, 2008 Welcome. http://www.legacygt.com/forums/showthread.php?t=67940 Link to comment Share on other sites More sharing options...
Legend Posted November 6, 2008 Share Posted November 6, 2008 Sounds good. There are several good open source tuners here. Have fun. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted November 6, 2008 Share Posted November 6, 2008 Testes? Link to comment Share on other sites More sharing options...
dudeondacouch Posted November 6, 2008 Share Posted November 6, 2008 Testes? Link to comment Share on other sites More sharing options...
testes1010 Posted November 6, 2008 Author Share Posted November 6, 2008 Testes? Last name is Estes. Nick name I got in highschool, it kinda stuck. Link to comment Share on other sites More sharing options...
Guest heightsgtltd Posted November 6, 2008 Share Posted November 6, 2008 Just busting balls (pun intended) Welcome aboard. Link to comment Share on other sites More sharing options...
Spec B Posted November 6, 2008 Share Posted November 6, 2008 Last name is Estes. Nick name I got in highschool, it kinda stuck. Thats nuts.. Welcome. BTW..If you use the live.com 25% discount, you could get a new Invidia on ebay for about $200! I am thinking of going with invidia, but I want a DP with an o2 bung at the bellmouth. Link to comment Share on other sites More sharing options...
ShadowImg Posted November 6, 2008 Share Posted November 6, 2008 Welcome from a fellow STLSubaru'er. Link to comment Share on other sites More sharing options...
testes1010 Posted November 6, 2008 Author Share Posted November 6, 2008 but I want a DP with an o2 bung at the bellmouth. Fact: putting the wbo2 sensor at the bellmouth will limit the life of the o2 sensor. Link to comment Share on other sites More sharing options...
testes1010 Posted November 6, 2008 Author Share Posted November 6, 2008 Welcome from a fellow STLSubaru'er. thanks! Link to comment Share on other sites More sharing options...
Spec B Posted November 6, 2008 Share Posted November 6, 2008 Fact: putting the wbo2 sensor at the bellmouth will limit the life of the o2 sensor. There is some debate about this one, and I don't know enough to know who's right. Some poeple say it is fine, some say further down the pipe is better (JDM DP 02 location), some say you could use the stock location...sigh. I just don't know. Link to comment Share on other sites More sharing options...
testes1010 Posted November 6, 2008 Author Share Posted November 6, 2008 some say you could use the stock location I would much rather see it on the bellmouth than the stock location. The pressure the sensor is seeing in the manifold collector could throw off the readings quite a bit. If you chose to put it in the bellmouth please use a heatsink to dissipate some the heat away from the sensor. Link to comment Share on other sites More sharing options...
Infamous1 Posted November 6, 2008 Share Posted November 6, 2008 I would much rather see it on the bellmouth than the stock location. The pressure the sensor is seeing in the manifold collector could throw off the readings quite a bit. If you chose to put it in the bellmouth please use a heatsink to dissipate some the heat away from the sensor. I am sure spec B was refering to the rear sensor location. It really depends on the sensor and the heat range. The LC-1's seem to die quickly if exposed to high egt's for a while. My Zeitronics Bosch sensor operates at a higher range (isn't even compatable with my LC-1) and has been installed in the bellmouth for over a year without any problems. It was even purchased used. So I recommend if buying an LC-1 to either install it perminately a distance from the turbo (before any cats) or just use it temporary to dial in fuel in the bellmouth then pull it. Oh and welcome Link to comment Share on other sites More sharing options...
Legend Posted November 6, 2008 Share Posted November 6, 2008 I put my LC-1 bung in the bellmouth location about 4" post-turbo. No heatsink. 9 months later it's still working well. I accepted the possibility that I might burn through sensors a little quicker than if located elsewhere. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
TheShad0w Posted November 6, 2008 Share Posted November 6, 2008 Hey man, good to see you over here too...guess we all grow into a legacy at some point.. Link to comment Share on other sites More sharing options...
testes1010 Posted November 6, 2008 Author Share Posted November 6, 2008 Hey man, good to see you over here too...guess we all grow into a legacy at some point.. I won't one as soon as they came out. I just couldn't justify trading in the WRX at the time so I waited a few years. Link to comment Share on other sites More sharing options...
NSFW Posted November 8, 2008 Share Posted November 8, 2008 I've seen your posts on RomRaider... glad to see that you're one of us now. Link to comment Share on other sites More sharing options...
testes1010 Posted November 10, 2008 Author Share Posted November 10, 2008 I've seen your posts on RomRaider... glad to see that you're one of us now. I'll still be spending time on the WRX forums but I'll be on here too. Link to comment Share on other sites More sharing options...
testes1010 Posted November 10, 2008 Author Share Posted November 10, 2008 100% bone stock LGT, 100% oem mapping. http://www.wrxfanatics.com/uploads/monthly_11_2008/post-367-1226285633.gif Link to comment Share on other sites More sharing options...
testes1010 Posted November 13, 2008 Author Share Posted November 13, 2008 Testes1010 STG1 map w/ Hallman PRO: http://www.wrxfanatics.com/uploads/monthly_11_2008/post-367-1226609080.gif stock mapping vs. Testes1010 STG1: http://www.wrxfanatics.com/uploads/monthly_11_2008/post-367-1226609087.gif Link to comment Share on other sites More sharing options...
Infamous1 Posted November 13, 2008 Share Posted November 13, 2008 I'm- Hallman Pro MBC(I don't want to hear it, a properly tuned car with a MBC will NOT blow your engine) Oh noes you are going to blow your motor For sake of discussion, what is your reasoning for going with the MBC? How must psi are pushing? Thats a big torque number for stg 1. Link to comment Share on other sites More sharing options...
TheShad0w Posted November 13, 2008 Share Posted November 13, 2008 My guess is about 18-19 psi-ish.. Link to comment Share on other sites More sharing options...
testes1010 Posted November 14, 2008 Author Share Posted November 14, 2008 For sake of discussion, what is your reasoning for going with the MBC? How must psi are pushing? Thats a big torque number for stg 1. I was after the absolute quickest response possible. I've ran & tuned many GM, perrin, & prodrive BCS' and nothing beats a quality MBC as far as response goes. I'm peaking just under 17psi. Link to comment Share on other sites More sharing options...
testes1010 Posted November 14, 2008 Author Share Posted November 14, 2008 My guess is about 18-19 psi-ish.. ssshhh, not till STG2...... btw, AFRs are in 11.2-11.4 neighborhood via LM-1. MAF Flow is peaking at 233g/sec. Link to comment Share on other sites More sharing options...
