chessyB Posted April 12, 2013 Share Posted April 12, 2013 I have been looking all day and I have had no luck on finding what my problem is. ALL my dash lights went out with my center consul. The first thing I did was change the fuse then as soon as I put the new one in it pops. Anyone have any ideas what it could be? I've kinda gotten used to it but if its a easy if I will fix it. Also did all 2nd gen outbacks come with keyless entry? If they didn't were can I look to see If mine did. Link to comment Share on other sites More sharing options...
johnegg Posted April 12, 2013 Share Posted April 12, 2013 you have a short, duh. do you have a replacement radio? if yes that is where i would start. but i don't even know if they are on the same circuit. Link to comment Share on other sites More sharing options...
Hemingway Posted April 12, 2013 Share Posted April 12, 2013 ^ you have a short somewhere. Installed anything recently? No, many do not have keyless entry...optional feature for that model/year: http://www.cars101.com/outback_archive98-99.html If you have it, you can verify by looking under the driver's side footwell. It will be a black box / module. If not, you can have an aftermarket unit of your choice installed if you have powered door locks ... I recently had a keyless entry / alarm system installed on my '98 Legacy Wagon. Link to comment Share on other sites More sharing options...
chessyB Posted April 12, 2013 Author Share Posted April 12, 2013 Yea I have a after market radio, ill pull it back out and make sure everything is good there, thanks for the help guys Link to comment Share on other sites More sharing options...
Hemingway Posted April 12, 2013 Share Posted April 12, 2013 I had a Sony head unit that caused a short (power mirrors and cigarette lighter socket would blow a fuse). Replaced it and the short disappeared (Alpine head unit that I spliced into the Subaru radio harness). Link to comment Share on other sites More sharing options...
chessyB Posted April 12, 2013 Author Share Posted April 12, 2013 I have a alpine, I'm thinking about just losing the head unit all together, and getting a 4 channle amp them getting a aux hook up for it. But for now ill pull my head unit out and see if there is any thing that could be a short. I also sound matted my door and put boss 6 1/2s it sounds good. Link to comment Share on other sites More sharing options...
Hemingway Posted April 12, 2013 Share Posted April 12, 2013 Make sure all the wires are insulated from one another ... if it has been spliced to the originating Subaru harness. Link to comment Share on other sites More sharing options...
chessyB Posted April 12, 2013 Author Share Posted April 12, 2013 I bought the eBay adaptor. I think maybe the cap on the remote wire come off, I guess I'll find out when I dig in there Link to comment Share on other sites More sharing options...
Bassnectar Posted April 13, 2013 Share Posted April 13, 2013 I have had so much stuff come lose from behind the headunit, solder is always a good idea. Link to comment Share on other sites More sharing options...
Hemingway Posted April 13, 2013 Share Posted April 13, 2013 Good idea if you have the time. I used insulated bullet connectors ... fast, easy and can be disconnected easily. Link to comment Share on other sites More sharing options...
monkeyposeur Posted April 13, 2013 Share Posted April 13, 2013 The problem wit head units is the stock ground shorts out. Run a new ground from the HU to the chassis and you'll be set. Link to comment Share on other sites More sharing options...
