afurgeson1 Posted June 21, 2009 Share Posted June 21, 2009 I am having trouble getting learning view to connect to my ECU. I am using a vag-com cable with windows xp and have no problems with romraider or ecuflash. I have an 05 lgt. any tips or help with a solution is greatly appreciated!!!:confused: Thanks Link to comment Share on other sites More sharing options...
merchgod Posted June 21, 2009 Share Posted June 21, 2009 make sure you are selecting the correct port in the upper left hand corner. Plug the cable in before you start LV OR hit the refresh icon if you plug it in after. If you don't know the correct COM port you can look under ports in the device manager (cable plugged in) or try each port that is available in the list. Also, you need to make sure the ignition is on, just like romraider (engine does NOT have to be running, though). Link to comment Share on other sites More sharing options...
afurgeson1 Posted June 21, 2009 Author Share Posted June 21, 2009 I am pretty sure i have the correct port chosen, and i have done exactly what you have listed and still it will not connect. I know the cable is good because it works with other programs?? Link to comment Share on other sites More sharing options...
merchgod Posted June 21, 2009 Share Posted June 21, 2009 post up the log from LV Link to comment Share on other sites More sharing options...
afurgeson1 Posted June 22, 2009 Author Share Posted June 22, 2009 I cant post a log because LV will not connect Link to comment Share on other sites More sharing options...
merchgod Posted June 22, 2009 Share Posted June 22, 2009 it generates a comm log in the same directory you have LV installed whether or not it connects. Or just click on comm log after it fails and cut and paste that. If that is greyed out, that means you are using an older version. DL 0.6a. Link to comment Share on other sites More sharing options...
afurgeson1 Posted June 22, 2009 Author Share Posted June 22, 2009 ok. I will tonight. Thanks again for your help Link to comment Share on other sites More sharing options...
afurgeson1 Posted June 25, 2009 Author Share Posted June 25, 2009 [18:57:33.6754272] Learning View version 0.6a [18:57:36.5395456] PassThruOpen returned 8 and DeviceID 0 [18:57:36.5495600] PassThruGetLastError returned 8, Message: no devices available [18:57:37.3707408] COM3 open [18:57:37.5109424] ECU Init [18:57:37.7212448] WRITE 6 bytes: 80 10 F0 01 BF 40 [18:57:38.0216768] READ 0 bytes: [18:57:39.8643264] No response to ECU Init [18:57:40.8958096] COM3 closed [18:57:44.0703744] PassThruOpen returned 8 and DeviceID 0 [18:57:44.0803888] PassThruGetLastError returned 8, Message: no devices available [18:57:44.1805328] COM4 open [18:57:44.1905472] ECU Init [18:57:44.1905472] WRITE 6 bytes: 80 10 F0 01 BF 40 [18:57:44.4008496] READ 68 bytes: 80 10 F0 01 BF 40 80 F0 10 39 FF A2 10 11 2F 12 50 53 06 73 FA CB A6 2B 81 FE A8 00 00 00 60 CE 54 F9 B1 E4 00 0C 20 00 00 00 00 00 DC 00 00 5D 1F 30 80 F2 26 00 00 43 FB 00 E1 00 00 00 00 00 00 C1 F0 C1 [18:57:46.2635280] ECU ID of 2F12505306 not found in definitions [18:57:46.3837008] COM4 closed Link to comment Share on other sites More sharing options...
merchgod Posted June 26, 2009 Share Posted June 26, 2009 This ECU is not supported. What this means is one of two things: 1. No one with the same ECU ROM revision as yours has ever uploaded that ROM for support to be added. Each model/year can have multiple revisions. You can upload your ROM for support to the romraider site. 2. You or your tuner changed the ECU id and it does not reflect the actual ROM revision. Cobb's mapping software allows you to do this, I believe. An OS tuner could also do this with a hex editor. Link to comment Share on other sites More sharing options...
afurgeson1 Posted June 29, 2009 Author Share Posted June 29, 2009 What should i do. i bought the car used. i have never tuned or anything. no mods. just a K&N panel air filter. Link to comment Share on other sites More sharing options...
merchgod Posted June 29, 2009 Share Posted June 29, 2009 With the vag-com cable you should be able to pull the ROM with Ecuflash as others have done with that cable (I think there's a FAQ or something about that cable on this site). So, you can pull the ROM and then PM it to me at the RomRaider site. I can tell what is going on then. Link to comment Share on other sites More sharing options...
