Fisch Posted July 18, 2011 Share Posted July 18, 2011 I searched to find a thread like this and I could not. What does everyone normally have their Audio Settings at? I was just curious seeing as all of us have a combo that suits our needs I have mine set up like this +1 bass, +2 mid, +2 treble 0 on the L R F B Normally listen to music on 13-15 when using CD's When I'm using this not so good radio transmitter for my ipod usually have it on 30 Also, what about your dimmer? Mine's always set on 3, sometimes I turn it down at late at night Link to comment Share on other sites More sharing options...
underground000 Posted July 18, 2011 Share Posted July 18, 2011 SRS on No settings changed 12" inverted subwoofer in trunk:) (inverted for space/smaller box) Vol: 10-13 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
RJS5689 Posted July 18, 2011 Share Posted July 18, 2011 Back when I had the OEM headunit and speakers I was at: +5 for bass +4 mid +4/5 for treble Fader and balance at R1 and R1. SRS WOW on I've never understood why some people don't adjust their fader and balance. Don't you want even sound from the driver's seat? Link to comment Share on other sites More sharing options...
OutbackXT05 Posted July 19, 2011 Share Posted July 19, 2011 Im at Bass:+2 mid:+4 high:+6 fade/balance: 0/0 All stock speakers plus a single 12 but i have a bass knob for that Link to comment Share on other sites More sharing options...
charlie_sheen Posted July 19, 2011 Share Posted July 19, 2011 Im at Bass:+2 mid:+4 high:+6 fade/balance: 0/0 All stock speakers plus a single 12 but i have a bass knob for that How easy was it to install the sub using the stock head unit? I did it like that on my old car and used a convertor box to draw signal from the rear speakers, im curious to know how you went about it to see if its worth buying another system for this car Link to comment Share on other sites More sharing options...
Max Capacity Posted July 19, 2011 Share Posted July 19, 2011 Back when I had the OEM headunit and speakers I was at: +5 for bass +4 mid +4/5 for treble Fader and balance at R1 and R1. SRS WOW on I've never understood why some people don't adjust their fader and balance. Don't you want even sound from the driver's seat? Great minds think alike. Not sure about the SRS in the 09 SpecB I don't think it has it. Volume is normally 13-14 with the windows up, 26+ with the windows down, at speed. Basically the same settings in 05 GT Wagon too. That has the oem sub. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
underground000 Posted July 19, 2011 Share Posted July 19, 2011 How easy was it to install the sub using the stock head unit? I did it like that on my old car and used a convertor box to draw signal from the rear speakers, im curious to know how you went about it to see if its worth buying another system for this car It is pretty easy, especially you already have some experience, this GT was my first car I personally installed a subwoofer. I have read on this forum where the plugs are in the firewall to run the battery wire, and you need taps for the headunit wires. I was looking into these Kickers because they have a built in amp, so it would be a lot easier installation wise, and the amp/sub match each other. My local BestBuy sells the lower end one for like $150 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
feelander Posted July 19, 2011 Share Posted July 19, 2011 http://legacygt.com/forums/showthread.php/your-radio-settings-set-ati-96327.html Link to comment Share on other sites More sharing options...
jagcars26 Posted July 19, 2011 Share Posted July 19, 2011 11 across the board. Link to comment Share on other sites More sharing options...
Slickvic Posted July 19, 2011 Share Posted July 19, 2011 11 across the board. Same here. http://bvimusic.com/wp-content/uploads/2011/01/SpinalTap_Goes-to-Eleven.jpg Link to comment Share on other sites More sharing options...
OutbackXT05 Posted July 19, 2011 Share Posted July 19, 2011 It was actually one of the easiest cars to put a sound system in in my opinion. Very easy to run the power wire (I used 2 gauge and it was still easy). And getting the head unit out is fairly easy too. Link to comment Share on other sites More sharing options...
ShadowImg Posted July 19, 2011 Share Posted July 19, 2011 Seems odd to me to set an EQ to the same positive setting across the board. What's the functional result of having all ranges (bass, mid, tre) at +5 rather than all at 0? I normally run Bass +3, Mid 0, Tre +2 Link to comment Share on other sites More sharing options...
xero287 Posted July 20, 2011 Share Posted July 20, 2011 5,4,5 ftw. Link to comment Share on other sites More sharing options...
