Chrisbl Posted April 28, 2012 Share Posted April 28, 2012 Both my steering wheel (at all times at higher speeds) and brakepedal feels kinda shaky and my front right wheel are making sounds while braking (see link). I've taken both calipers on and off the disc and made sure it's all seated correctly. Does anyone know what the problem might be? Link to comment Share on other sites More sharing options...
underground000 Posted April 28, 2012 Share Posted April 28, 2012 you grease the moving parts and torque the bolts to specs? lithium grease is good 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Chrisbl Posted April 28, 2012 Author Share Posted April 28, 2012 Greasing all moving parts tomorrow after work, hoping it will sort itself out then Link to comment Share on other sites More sharing options...
RuskiTrombone Posted April 29, 2012 Share Posted April 29, 2012 I see new rotors and pads in your future. At the very least you may have to resurface the rotors. Link to comment Share on other sites More sharing options...
Chrisbl Posted April 29, 2012 Author Share Posted April 29, 2012 I see new rotors and pads in your future. At the very least you may have to resurface the rotors. So do I.. Trying to figure out if the European 2.0R uses the same brakes as the USDM 2.5i as we speak (believe it or not, it's cheaper to buy aftermarket parts from the US then buying OEM in Norway).. Link to comment Share on other sites More sharing options...
Chrisbl Posted April 30, 2012 Author Share Posted April 30, 2012 Seems like the wheel bearing has gone bad.. Link to comment Share on other sites More sharing options...
