m sprank Posted July 29, 2010 Share Posted July 29, 2010 Shop located in Escondido. Full fabrication services available. Specializing in Subarus, Nissans, Hondas and domestics. No job too big or small. We now offer sport bike services. Address is: 1948 Don Lee Place, Suite 6 Escondido, CA 92029 Phone: 760-781-1126 email: sales@infamousperformance.net Please call for appointments. For custom work we charge $85 per hour plus materials. For standard things we will quote a price. Some basics we get lots of request for; Fender rolling $50 per corner ($150 for all 4) Power & Exhaust Headers Back (Headers, Uppipe, Downpipe, Axleback) $380 Headers & Uppipe (Headers, Uppipe & Downpipe Only) $359 Uppipe (Uppipe, Downpipe) $299 Uppipe Back (Uppipe, Downpipe, Midpipe & Axleback) $320 Downpipe Back (Downpipe, Midpipe & Axleback) $195 Downpipe (Downpipe) $175 Catback/Axleback $65 Hardened Exhaust Hangers $65 Turbo/Injectors/Fuel Pump (W/No Air Pump and Side Feed Injectors) Includes: Oil Change, Safety Bracket Replacement, Coolant Replacement, SS Oil Feed Line Install $675 Turbo/Injectors/Fuel Pump (W/Air Pump and Top Feed Injectors) Includes: Oil Change, Safety Bracket Replacement, Coolant Replacement, SS Oil Feed Line Install $790 Turbo $295 Turbo (With Uppipe & Downpipe) $350 Injectors (W/No Air Pump and Side Feed Injectors) $215 Injectors (W/Air Pump and Top Feed Injectors) $325 Fuel Pump $85 IP&T SS Turbo Oil Line (w/Turbo Install) $85 IP&T SS Turbo Oil Line $170 Suspension Springs/Struts/Shocks (Labor Only) $200 Koni Sport Struts Inserts (Labor Only, Impreza '92-'07) $320 Koni Sport Struts Inserts (Labor Only, Legacy '05+, Impreza '08+) $295 Coil Over Install and ride height set $300 Rear Sway Bar w/oMounts (Laborl Only, Impreza '92-'07) $85 Rear Sway Bar (Labor Only, Impreza '08+, Legacy '05+, Includes Strut Rotation) $170 Front Sway Bar (Impreza '02+, Legacy '05-'09) $85 Front Sway Bar (Impreza '92-'01, Legacy '92-'04) $65 Drive Axle w/CV Joint (Labor Only) $95 Drive Axle w/CV Joint (Parts & Labor) $260 Wheel Bearing (Parts & Labor)(Impreza '93-07, Legacy '91-04) $250 Wheel Bearing w/Hub (Parts & Labor)(Impreza '93-07, Legacy '91-04) $360 Wheel Bearing w/Hub (Parts & Labor)(Impreza '08+, Legacy '05+) $295 Mounts & Bushings Motor Mounts $155 Transmission Mount $75 Anti-Lift Kit $175 Front Lower Control Arm Rear Bushings (Legacy '05+, Impreza '08+) $175 Front Lower Control Arm Inner & Rear Bushings (Legacy '05+, Impreza '08+) $200 Front Roll Center Kit (Legacy '05+, Impreza '08+) $165 Front LCA Bushings & Roll Center Kit (Legacy '05+, Impreza '08+) $225 Steering Rack Bushings $160 Rear Subframe Bushings $115 Rear Differential Locking Bolts $65 Rear Differential Mount Bushings $145 Short Shifter (5MT) $85 Short Shifter (6MT) $135 Short Shifter w/Bushings (5MT) $125 Short Shifter w/Bushings (6MT) $160 Short Shifter w/Bushings and Linkage (5MT) $155 Short Shifter w/Bushings and Linkage (6MT) $175 Electronics Electronic Boost Gauge $150 EGT Gauge $185 A/F Gauge $175 Oil Pressure/Temp Gauge (In Block, only avail on certain models) $175 Oil Pressure/Temp Gauge (Filter Style) $150 Electronic Boost Controller Grimspeed Style $55 Stereo (Plug & Play) $85 Hella Horns (Parts, Labor & Custom Wiring Harness)(No Bumper Removal)(+$15 for Black) $155 Hella Horns (Parts, Labor & Custom Wiring Harness)(Bumper Removal Required)(+$15 for Black) $195 DDM Tuning HID (Parts & Labor w/Wiring Harness) (No Bumper Removal) $155 DDM Tuning HID (Parts & Labor w/Wiring Harness) (Bumper Removal Required) $200 Maintenance Oil Changes Subaru Synthetic 5w30 w/Subaru Oil Filter $70 Shell Rotell T6 5w40 w/Subaru Oil Filter $65 Standard Conventional Oil 5w30 w/Oil Filter $30 Bring your own Oil/Filter Change $20 Coolant Changes Subaru Long Life Coolant Drain/Fill $95 Subaru Long Life Coolant Drain/Fill w/Redline Water Wetter $120 Subaru Super Long Life Coolant Drain/Fill (100k Blue Subaru Fluid) $120 Subaru Super Long Life Coolant Drain/Fill w/Redline Water Wetter $135 Gear & Transmission Changes Subaru 5MT Front Diffy/Trans, Rear Diffy, Subaru Extra S Fluid $95 Subaru 6MT Front Diffy/Trans, Rear Diffy, Subaru Extra S Fluid $110 Subaru 4EAT or 5EAT ATF, Subaru ATF, Front & Rear Diffy Extra S w/Subaru ATF Spin on Filter $140 Subaru 4EAT or 5EAT ATF, Subaru ATF, w/Subaru ATF Spin on Filter $120 30k Services Included in 30K Mile Service Replacement of: Coolant (Subaru Long Life) Brake Fluid (Full Flush with ATE Superblue or Standard) Transmission Fluid (Subaru OEM or Subaru Extra S) Clutch, Front and Rear Diff Fluid (Subaru Extra S) Oil Change (Standard or FULL Synthetic w/Subaru Oil Filter) Belts Air Filter Rotate Tires Inspection of: Brakes Parking Brake Pricing: 30k Using Conventional Engine Oil & Subaru Oil Filter $385 30k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $405 *On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles. Non-Turbo 30k Using Conventional Engine Oil & Subaru Oil Filter $405 30k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $440 *On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles. *On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs. **On Forester $20 extra due to plug placement. Optional Items (includes parts & labor) Water Wetter $15 Alternator & Power Steering Belt (H6 Engines) $25 AC Belt (08+ WRX) $85 Cabin Air Filter $45 Compression Test (Non-Turbos) $20 Compression Test (Turbo Cars) $100 60k Services Included in 60K Mile Service Replacement of: Belts Coolant (Subaru OEM w/conditioner) Brake Fluid (Full Flush with ATE Superblue or Standard fluid) Transmission Fluid (OEM or Subaru Extra S) Front and Rear Diff Fluid (Subaru Extra S) Clutch fluid (Standard or ATE Superblue) Oil Change (Standard or FULL Synthetic w/OEM Oil Filter) Fuel Filter (if applicable) Air Filter Spark Plugs Rotate Tires Inspection of: Brakes Parking Brake Pricing: Non-Turbo H4 Engines 60k Using Conventional Engine Oil & Subaru Oil Filter $405 60k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $440 *On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles. Turbo H4 & Non-Turbo H6 Engines 60k Using Conventional Engine Oil & Subaru Oil Filter $485 60k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $500 *On 09+ Impreza/Legacy (and cars with Subaru Super Long Life Coolant) $50 discount due to the coolant change interval being 100k miles. *On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Filter Type), cost for AT cars is $45 Extra due to Fluid and Filter costs. **On Forester $20 extra due to plug placement. ***On H6 Models $35 extra due to plug placement and quantity. Optional Items (includes parts & labor) Water Wetter $15 Alternator & Power Steering Belt (H6 Motors) $25 AC Belt (08+ Impreza) $85 Cabin Air Filter $45 Compression Test $20 90k Services Included in 90K Mile Service Replacement of: Coolant (Subaru Long Life) Brake Fluid (Full Flush with ATE Superblue or Standard Fluid) Belts Transmission Fluid (OEM or Subaru Extra S) Clutch Fluid Front and Rear Diff Fluid (Subaru Extra S) Oil Change (Standard or FULL Synthetic w/OEM Oil Filter) Fuel Filter (if applicable) Air Filter Rotate Tires Spark Plugs (Non-Turbo Cars) Inspection of: Brakes Parking Brake Pricing: Turbo 90k Using Conventional Engine Oil & Subaru Oil Filter $385 90k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $405 Non-Turbo 90k Using Conventional Engine Oil & Subaru Oil Filter $405 90k Using Subaru Synthetic or T6 Rotella Engine Oil & Subaru Oil Filter $440 Optional Items (includes parts & labor) Water Wetter $15 Alternator & Power Steering Belt (H6 Engines) $25 AC Belt (08+ WRX) $85 Cabin Air Filter $45 Compression Test (Non-Turbos) $20 Compression Test (Turbo Cars) $100 *On Automatic Transmission Cars, we will do a drain and fill of the fluid and replace the ATF Filter (Spin on Type), cost for AT cars is $45 Extra due to Fluid and Filter costs. **On Forester $20 extra due to plug placement. Timing Belt Service Includes Replacement of: Timing Belt Timing Belt Tensioner Timing Belt Pulleys Seals Water Pump Thermostat Coolant Flush Timing Belt Service Pricing: Turbo Timing Belt Service $725 90k Service w/Timing Belt Service $675 Non-Turbo Timing Belt Service $700 90k Service w/Timing Belt Service $650 Gear & Transmission Fluid Changes Subaru 5MT Front Diffy/Trans, Rear Diffy, Subaru Extra S Fluid $95 Subaru 6MT Front Diffy/Trans, Rear Diffy, Subaru Extra S Fluid $110 Subaru 4EAT or 5EAT ATF, Subaru ATF, Front & Rear Diffy Extra S w/Subaru ATF Spin on Filter $140 Subaru 4EAT or 5EAT ATF, Subaru ATF, w/Subaru ATF Spin on Filter $120 Subaru 4EAT or 5EAT ATF, Subaru ATF, Front & Rear Diffy Extra S $120 Subaru 4EAT or 5EAT ATF, Subaru ATF $100 Misc. AC/Alt-PS Belts (Per Belt except 08+ WRX AC) $30 Compression Test (Impreza & 92-09 Legacy) $120 Compression Test w/Plugs NGK OEM or 1 Step Colder (Impreza & 92-09 Legacy) $155 Spark Plug Replacement w/NGK OEM or 1 Step Colder (Impreza & 92-09 Legacy) $135 Compression Test (2010+ Legacy, All Foresters, All Outbacks) $140 Compression Test w/Plugs NGK OEM or 1 Step Colder (2010+ Legacy, All Foresters, All Outbacks) $175 Spark Plug Replacement w/NGK OEM or 1 Step Colder (2010+ Legacy, All Foresters, All Outbacks) $155 Brakes Standard Fluid Flush = $50 ATE Super Blue Fluid Flush = $95 ATE Fluid Flush + Stainless Steel Line install (02-07 Imprezza) = $190 ATE Fluid Flush + Stainless Steel Line install (08+ Imprezza) = $210 ATE Fluid Flush + Stainless Steel Line install (05-09 Legacy) = $220 Front Pads Installed = $50 Front and Rear Pads Installed = $90 w/fluid flush = $130 Front Rotors and Pads Installed = $90 Front and Rear Rotors and Pads = $170 w/fluid flush = $210 Clutches 5MT Clutch & Flywheel Labor Only w/ Extra S Fluid Change $495 Clutch & Flyhwheel Labor w/Flywheel Resurface & Extra S Fluid Change $575 6MT Clutch & Flywheel Labor Only w Extra S Fluid Change $505 Clutch & Flywheel Labor w/Flywheel Resurface & Extra S Fluid Change $580 Prices valid on stock vehicles in good working condition (no major rust, broken bolts, etc). Prices are labor only, materials extra (unless otherwise noted). Link to comment Share on other sites More sharing options...
istealfrombums Posted July 29, 2010 Share Posted July 29, 2010 Good luck Mike, hopefully everything works out for the best. Thumbs up from me! Link to comment Share on other sites More sharing options...
GravityGear Posted July 29, 2010 Share Posted July 29, 2010 sick. Link to comment Share on other sites More sharing options...
socalsleeper Posted July 29, 2010 Share Posted July 29, 2010 I wish you luck, let me know if you ever need a hand i know somtimes an extra part of "experianced" hands makes the job soooo much faster. Jose and i pulled an engine super quick!!! So it makes a difference Link to comment Share on other sites More sharing options...
socalsleeper Posted July 29, 2010 Share Posted July 29, 2010 I would suggest having people post to your I-trader, per service call to have a runing log of user experiance. Link to comment Share on other sites More sharing options...
m sprank Posted July 29, 2010 Author Share Posted July 29, 2010 Thanks. I will deff keep the iTrader up. I work hard to keep customers happy. Check my feedback now. Still want to stop by when you do that clutch. You can borrow my compressor and I can be your extra set of experienced hands, lol. My old race mechanic is coming back to Cali. He was Crew Chief last year and Race Team Manager this season. Spent the last 4 years working as a Factory Race Team Mechanic for Suzuki and Can Am. Hopefully when he gets here in late August we can open a shop together. Two ex-pro racers and mechanics working on your car. Together we have over 50 years racing and mechanical experience. He is a welder and fabber too. He used to make all my Chassis and Suspensions. Mig and Tig, 4130 specialty. Also a Penske trained shock technician. He does all the rebuilds on my Custom Axxis, PEP, and Ohlins shocks. Together we can do anything. His family owns San Marcos Street Rod Factory and has been building custom Hot Rods in San Marcos for 30 years. They are innovators of air ride technology. Lots of hard core cover vehicles and Good Guy best of shows from that shop. Good things in the pipeline. Get the best from the best. My prices wont be this low forever. Got to start somewhere. Link to comment Share on other sites More sharing options...
TSiWRX Posted July 29, 2010 Share Posted July 29, 2010 Best of luck! Free bump. And I'd use ya if you were closer. I'd love to pay a known-good-work member from the community, someone whom I trust, and just leave the car with them, in my own garage/driveway, while I take the kiddo to the park or something - and help out their financial situation at the same time. That's good Karma, all-around. Best of luck! <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
B-BGTLimited Posted July 29, 2010 Share Posted July 29, 2010 Can you come and rotate my tires for me? I hate dealers. I'll pick up the Airfare... Good luck with the new business. It's nice to be one's boss but sometimes it can be hard to keep going. Link to comment Share on other sites More sharing options...
m sprank Posted July 29, 2010 Author Share Posted July 29, 2010 Any tri-state members who need a hand can pay to ship my tools (or rent me what I need) and we can schedule. I am originally from Pearl River, New York. Any chance to get home and I take it. I am only back on the West Coast for the Wife. She is a So Cal girl. Link to comment Share on other sites More sharing options...
socalsleeper Posted July 29, 2010 Share Posted July 29, 2010 Funny thing is that this is what I wanted to do originaly, race team tech, that is why I went to work for porsche. Things where too slow to hold out for the opertunity. I like having the lights on at home. Link to comment Share on other sites More sharing options...
mattg Posted July 29, 2010 Share Posted July 29, 2010 Good luck on your new ventures! Link to comment Share on other sites More sharing options...
mk6933 Posted July 29, 2010 Share Posted July 29, 2010 Good luck Mike!! I should consider myself lucky... you just did my springs and clear my headlight 5 days ago Link to comment Share on other sites More sharing options...
oside13 Posted July 29, 2010 Share Posted July 29, 2010 Mike I'm working in OC the next 2 days I'm gonna leave the pulley next to my front door on the left side if you want to come by and scoop it up. In case you forgot what house it is look for the 54 chevy in front. Link to comment Share on other sites More sharing options...
socalsleeper Posted July 29, 2010 Share Posted July 29, 2010 Free pulley yaeah!!! Link to comment Share on other sites More sharing options...
m sprank Posted July 29, 2010 Author Share Posted July 29, 2010 Its a replacement for my 5EAT. Gave MiniStiGuy my Perrin as a going away gift. Just posted a more detailed pricing list. I think the rates are VERY competitive. Keep in mind that I come to you. So scheduling and hassle are a minimum. Link to comment Share on other sites More sharing options...
gotsflat4love Posted July 29, 2010 Share Posted July 29, 2010 Oh NICE!!!! I will definately be comming to your for installs, since we had a similar experiance with.... well, you know who. Link to comment Share on other sites More sharing options...
m sprank Posted July 29, 2010 Author Share Posted July 29, 2010 Situations like that are part of why I am doing this. Hope to see you soon. Link to comment Share on other sites More sharing options...
Kemosavi Posted July 30, 2010 Share Posted July 30, 2010 Good luck with that Mike. He knows his stuff. And has been all too helpful with me and my venture from VW's into Subaru's. I would give this guy business any day. Link to comment Share on other sites More sharing options...
laz Posted July 30, 2010 Share Posted July 30, 2010 GL! I wish you were closer to Florida. I need to have some work done. X --- Link to comment Share on other sites More sharing options...
a.lim Posted July 30, 2010 Share Posted July 30, 2010 you and infamous should open up a shop! Link to comment Share on other sites More sharing options...
a.lim Posted July 30, 2010 Share Posted July 30, 2010 can you PM me a quote for spark plug installation? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted July 30, 2010 Share Posted July 30, 2010 Might recommend checking in with GTTuner. He is head of a Nissan service department last I checked, and he does exactly what you do on many weekends. Might be able to add a little something to your entrepreneurial venture. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
m sprank Posted July 30, 2010 Author Share Posted July 30, 2010 Spark plugs are $100 for removal and replacement, unless combined with a 60k miles service. You supply the plugs. I have the anti-seize and dielectric grease. Link to comment Share on other sites More sharing options...
Naylor Posted July 30, 2010 Share Posted July 30, 2010 you and infamous should open up a shop! bingo! i'll be sending you an email mike! Link to comment Share on other sites More sharing options...
0verboost Posted July 30, 2010 Share Posted July 30, 2010 Hey Mike, is the $50 for 5spd fluid change include fluids? Link to comment Share on other sites More sharing options...
