volodyalysak Posted January 5, 2013 Share Posted January 5, 2013 Short story. After my ej25 rebuilt i had idle issues, my subaru tech cleand throttle body and also he tightened up cam sprockets on the left side. Idle problem was fixed, but car lost 30-40 % of power, like i'm runing wastegate pressure. Turbo spools, but there is no kick to it, it spools steady from 3500 rpm to 5000. Anyone experienced it ??? Link to comment Share on other sites More sharing options...
volodyalysak Posted January 6, 2013 Author Share Posted January 6, 2013 Anyone ?? Do i need to rephrase question ? Post ? Thanks Link to comment Share on other sites More sharing options...
ripemeat Posted January 6, 2013 Share Posted January 6, 2013 the cam sprockets bolt to the cam and has a peg in the cam so the sprocket can't slide back and forth. the bolt tightness has no effect on operation unless it's loose and the cam is wobbling around. look elsewhere. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted January 6, 2013 Share Posted January 6, 2013 If the throttle body was cleaned, maybe the TMIC wasn't reinstalled correctly? Big boost leak? MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 6, 2013 Share Posted January 6, 2013 Timing jumped. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
volodyalysak Posted January 6, 2013 Author Share Posted January 6, 2013 ok, will check TMIC. Link to comment Share on other sites More sharing options...
