Gravet Posted July 25, 2010 Share Posted July 25, 2010 I have an Innovate LC-1 with gauge. The install and calibration went great and the gauge has been showing consistent, legitimate readings. The problem arises when I hook the wideband up to my computer. I initially used the serial port on my computer and it never received any data so I hooked it up to my USB port, via a USB>Serial cable. Still getting no readings with the LMsoftware or Romraider. The OS is XP with the service pack 3. Any ideas? Link to comment Share on other sites More sharing options...
Gravet Posted July 25, 2010 Author Share Posted July 25, 2010 When I run the LM programmer software I get the following message: "Please connect device to serial port and switch on" Link to comment Share on other sites More sharing options...
Gravet Posted July 25, 2010 Author Share Posted July 25, 2010 Driver issue. Problem solved. Now if I could just figure out how to get RR to read the LC-1. I use plugin menu. Choose the port. Then check and uncheck LC-1... I'll keep playing with it but don't hesitate to post other tips that have worked. Link to comment Share on other sites More sharing options...
Gravet Posted July 25, 2010 Author Share Posted July 25, 2010 All problems solved. Link to comment Share on other sites More sharing options...
