Voytech Posted April 23, 2008 Share Posted April 23, 2008 Simple question. I noticed a faint but high pitched squealing that's speed dependent and I suspect it's the worn out brake pads. My car is at 40k. I can't really inspect the pads without taking the wheels off and I'm at work, hence my question. Thanks. Link to comment Share on other sites More sharing options...
Reuben Posted April 23, 2008 Share Posted April 23, 2008 Allot of places in NZ offer free brake checks, i'm sure there'll be someine nearby who can do that. and remember, front brakes will wear atleast twice as quick as the rears. Link to comment Share on other sites More sharing options...
rc0032 Posted April 23, 2008 Share Posted April 23, 2008 Its not a simple question due to the number of factors involved. At 40k just go ahead and do it. Link to comment Share on other sites More sharing options...
Voytech Posted April 23, 2008 Author Share Posted April 23, 2008 Alright, so after a more detailed research, I found a thread like this and it ranges from 20k to 50k on the LGT's with most leaning closer to the 50k side. Didn't find anything on the 2.5i's but I'm guessing since the weight of the car is similar and my rotors are smaller, the pads would wear quicker. Time for the Hawk HPS pads. Link to comment Share on other sites More sharing options...
Scotty Posted April 23, 2008 Share Posted April 23, 2008 It is more dependant on where you drive, highway vs. surface streets, and how you drive, aggressive vs. grandma. Depending on the wheel you have, like the GT wheels, you can inspect it without removing the wheel. Link to comment Share on other sites More sharing options...
Legacy05 Posted April 23, 2008 Share Posted April 23, 2008 ^ +1 to that, I didn't track/race my car so I changed my pads out at like 55k miles ... and they still look pretty good actually ... Link to comment Share on other sites More sharing options...
SLegacy99 Posted April 23, 2008 Share Posted April 23, 2008 90,000. Link to comment Share on other sites More sharing options...
schneiks Posted April 23, 2008 Share Posted April 23, 2008 I'm at 22K and mine just started squealing. I did a little searching on here and I think it might be caused by the tire cleaner I sprayed on the rims/tires. Have you used a product like that lately? It already seems to be going away less than a week later. Link to comment Share on other sites More sharing options...
john_knoxville Posted April 24, 2008 Share Posted April 24, 2008 Depending on the wheel you have, like the GT wheels, you can inspect it without removing the wheel. what/how would you inspect, and what would be your indicators/parameters that it is time for a change? thanks Link to comment Share on other sites More sharing options...
itsme Posted April 24, 2008 Share Posted April 24, 2008 I change mine when I did my own 30k service. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Voytech Posted April 24, 2008 Author Share Posted April 24, 2008 Sooo, a little update. I noticed the sound is weird. It sounds "almost" like a metal to metal squeal. But it's not. After I parked in the driveway tonight, I saw a nail in the tire. I think it's not squealing but more of a whistling sound of air escaping through a tiny hole. I will fix the tire tomorrow and see if that was it. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted April 24, 2008 Share Posted April 24, 2008 45k, still no problem. PA inspection checked them at a 9 last year, and they were a 6 this year...assuming it will be a 3 next year. I'll probably replace them then. Link to comment Share on other sites More sharing options...
Xenonk Posted April 24, 2008 Share Posted April 24, 2008 I've changed pads as little as 1,000 miles... but then again, not everyone is driving at a race track. Keefe Link to comment Share on other sites More sharing options...
SlingXShot Posted April 24, 2008 Share Posted April 24, 2008 It all depends on your driving style. Some people change break pads every 10K miles... like me... doesn't matter what car. Link to comment Share on other sites More sharing options...
700watts Posted April 24, 2008 Share Posted April 24, 2008 I changed mine at 40k to put on slotted rotors but I had plenty of life left on them Link to comment Share on other sites More sharing options...
Scotty Posted April 25, 2008 Share Posted April 25, 2008 what/how would you inspect, and what would be your indicators/parameters that it is time for a change? thanks Visual inspection. If you get at the right angle, you can see the pad thickness. 1.5mm is the minimum you should have. New pads are around 11mm. Link to comment Share on other sites More sharing options...
Voytech Posted April 25, 2008 Author Share Posted April 25, 2008 So I checked it all out with the help of a friend. Pads are fine. No rocks stuck behind the shield. All of the rubber boots are fine. All points to the wheel bearing. ****!. Link to comment Share on other sites More sharing options...
biggggant Posted April 26, 2008 Share Posted April 26, 2008 i just did mine at 38k and I was told about 500 miles ago I had 10% pad left Link to comment Share on other sites More sharing options...
f1anatic Posted April 26, 2008 Share Posted April 26, 2008 I changed a set at around 22 K and it was still half good. I put somewhat softer (= better pads but unfortunately dustier) and at 43 K they are half worn. That being said, I am still on my OEM rotors which are still holding and they are not warped - but not window glass smooth either. One thing I do seem to remember is that my rear pads were more worn out compared to my fronts (compared to new ones). Yes, they have less material to start with (new) but I do recall my rears seemed excesively worn out compared to fronts. At the time, one other member here also changed his. Link to comment Share on other sites More sharing options...
SubieSteve Posted April 27, 2008 Share Posted April 27, 2008 I've had my car back to the dealer twice b/c of warped rotors. The brakes on this car suck. The dealer did say that if it happens one more time < 36K they would replace them under warranty (they've been cut twice now). Funny thing...the dealer did try to pin it on me, saying it's a combo of hard driving and my '07 OEM rims on the car. I threw it back at him saying "or it could be that the last time I had it in here your mechanic only tightened one lug nut per wheel - the rest were finger tight". The look on his face was priceless! My wife drives the car so there is no "hard driving" involved either. If it happens under 36K I'll let them deal with it, if not I'm putting on a better set. Link to comment Share on other sites More sharing options...
