Instanced Posted August 25, 2010 Share Posted August 25, 2010 As the title states, Looking at 275/35/R18 on 18X10 +30 rims... paticularily rota grids... I LOVE fat/wide tires... and I LOVE the look of the Rota Grids... I know 10" is excessive... Do they even fit under legacy's? should I plan on fender rolling? Does anyone run 275's on their car? pictures? Link to comment Share on other sites More sharing options...
Windy Road Posted August 25, 2010 Share Posted August 25, 2010 I might be mistaken but I think the largest tire some one has put on a legacy is a 255 or a 265. Your going to have to roll the fenders and maybe a slight pull to fit anything large. Though it might not be helpful, I run a 235 on a 17x8 +48 and my setup is close to my fenders as is. Though yesterday I did some how catch the fender lip and pulled it down, time to roll my fenders. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
Instanced Posted August 25, 2010 Author Share Posted August 25, 2010 From the FAQ sticked thing: 275/30/18 (tallest tire you can mount without fender clearing issues on a 2" lowered car if you get the right offset) My car isn't lowered at all... I'd like to lower it but only about an inch... and 275/35 = closest to factory tire size... in height not width obviously... So basically the rim/tire with that little offset won't clear my shocks or my fenders? .I would think it would clear my strut/spring ok, it's the fenders i'm more worried about... I guess i could always go skinnier ... Link to comment Share on other sites More sharing options...
JonLGT Posted August 26, 2010 Share Posted August 26, 2010 275 is a pretty rediculous size for our cars, good luck clearing that up front. Link to comment Share on other sites More sharing options...
whitetiger Posted August 26, 2010 Share Posted August 26, 2010 you can do a 285/30/18, but....and thats a big but, you cannot lower your car too much. at this width, unless you do some serious modification to the fenders, the tire will stick out past them. this means that you have to make sure your fender does not bottom out on the tire. to do this, you need to have some ride height clearance and have stiff enough springs to keep the fender off the tire. you will need coilovers with custom super stiff spring rates and the ride will be very stiff. anything bigger than 245 or 255 is not very streetable since you need what essentially is racing suspension to make a 275 or 285 fit well. I think if you stretch a 245/35/18 across a 10" rim it will look wide enough for you. Link to comment Share on other sites More sharing options...
Instanced Posted August 26, 2010 Author Share Posted August 26, 2010 This sounds like it's going to be a huge pain to figure out... maybe i'll stick with 9.5's with 255's... that should work... less headaches with them too from the sounds of it... I'm looking to buy the rims/tires and just toss them on the car and be good to go... don't want to play with suspension yet (though I should probably upgrade those first)... Link to comment Share on other sites More sharing options...
whitetiger Posted August 26, 2010 Share Posted August 26, 2010 ^you still are gonna want to roll/pull the crap out of your fenders to fit that Link to comment Share on other sites More sharing options...
Instanced Posted August 27, 2010 Author Share Posted August 27, 2010 ^you still are gonna want to roll/pull the crap out of your fenders to fit that I don't want to do that. I want these rims: http://www.wheeldude.com/catalog/product_info.php?products_id=5738&osCsid=3cb75c7df24645e6e1345b6ca0f70145 Riding on stock suspension, stock height Link to comment Share on other sites More sharing options...
Draco-REX Posted August 27, 2010 Share Posted August 27, 2010 I don't want to do that. I want these rims: http://www.wheeldude.com/catalog/product_info.php?products_id=5738&osCsid=3cb75c7df24645e6e1345b6ca0f70145 Riding on stock suspension, stock height Since you have a spec.B those rims will be: Offset: ET48 - ET38 = 10mm Width: 9.5" - 7" = 2.5" * 25.4 = 63.5mm / 2 = 31.75mm Total: 41.75mm or about 1 5/8" closer to the fender than the stock rims. And that's just the rim, not counting any increases in tire width. They won't fit without fender or suspension mods. A simple fender roll might work if the tires aren't insanely huge. Link to comment Share on other sites More sharing options...
whitetiger Posted August 27, 2010 Share Posted August 27, 2010 I don't want to do that. I want these rims: http://www.wheeldude.com/catalog/product_info.php?products_id=5738&osCsid=3cb75c7df24645e6e1345b6ca0f70145 Riding on stock suspension, stock height you are still gonna need more camber adjustment and fender rolling. Link to comment Share on other sites More sharing options...
Polo08816 Posted August 27, 2010 Share Posted August 27, 2010 you are still gonna need more camber adjustment and fender rolling. Just keep doing the camber adjustments until you've reached the "hellaflush" range. Link to comment Share on other sites More sharing options...
Frogg Posted August 27, 2010 Share Posted August 27, 2010 i was thinking of this too. 18x10 but with a 265/30-18 on an outback xt with legacy coilovers....but those flares may be trouble... Link to comment Share on other sites More sharing options...
Instanced Posted August 28, 2010 Author Share Posted August 28, 2010 Since you have a spec.B those rims will be: Offset: ET48 - ET38 = 10mm Width: 9.5" - 7" = 2.5" * 25.4 = 63.5mm / 2 = 31.75mm Total: 41.75mm or about 1 5/8" closer to the fender than the stock rims. And that's just the rim, not counting any increases in tire width. They won't fit without fender or suspension mods. A simple fender roll might work if the tires aren't insanely huge. Spec B rims are ET55 I thought? (I have 18"... not sure if the offsets were different with the 17's) and I think you are off a bit... From the center of the rim, you have an ET55 and ET38, therefore you're bringing the rim 17mm closer towards the hub... now take the rim widths... 7" and 9.5" which is 2.5" diff, divide that by 2, since half is on one side of the rim center and the other amount is equally on the other side... so that's 1.25in and that amount it increased towards the fender... which equals about 31mm, subtract the 17mm from that and you're left with roughly 1/2 inch closer to the fender... going the other way is a different story, because i'll be adding the 17mm to the 1.25in which brings it in significantly more... does that make sense? it did in my head... and I could be completely wrong. Link to comment Share on other sites More sharing options...
Draco-REX Posted August 28, 2010 Share Posted August 28, 2010 spec.B rims are ET48. The regular LGT rims are ET55. Lower offset pushes the wheels outwards, so you're adding the difference to check fender clearance. If you want to work this out visually, go here: http://www.rimsntires.com/rt_specs.jsp Link to comment Share on other sites More sharing options...
