bkv348 Posted December 24, 2014 Share Posted December 24, 2014 Currently I just have a stage 1 tune through my cobb ap but I have purchased a catless invidia dp and will be using the stage 2 tune until I get my pro tune. Once I get tunned I also will be getting a cobb sf air intake and I'm afraid of a boost creep. So, if I were to get a boost control solenoid when I went to get a pro tune would this help prevent boost creep? Link to comment Share on other sites More sharing options...
Mike07LGT Posted December 25, 2014 Share Posted December 25, 2014 Help save your wallet and dont buy the Cobb intake. Its a waste of money. Get the downpipe and a protune and you will be more than happy with the results 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
bkv348 Posted December 25, 2014 Author Share Posted December 25, 2014 I have heard that before, thanks! I know that boost creep is a mechanical issue and can't be fixed with a boost solenoid just wishful thinking I guess. Link to comment Share on other sites More sharing options...
Akasa Posted December 25, 2014 Share Posted December 25, 2014 It can however be fixed with an external wastegate Link to comment Share on other sites More sharing options...
compsurge Posted December 25, 2014 Share Posted December 25, 2014 Why are you afraid of boost creep? What makes you think it's going to happen? Deal with it if it does. It's unlikely you'll have anything happen out of the ordinary unless your car is already broken. Link to comment Share on other sites More sharing options...
bkv348 Posted December 25, 2014 Author Share Posted December 25, 2014 Because I live in a colder climate and in the winter, like right now I'm pushing 16 psi when target is 14.5 +/-0.8 and Im afraid when I put my dp on it will be even higher. Link to comment Share on other sites More sharing options...
BoostSLUG Posted December 25, 2014 Share Posted December 25, 2014 Help save your wallet and dont buy the Cobb intake. Its a waste of money. Get the downpipe and a protune and you will be more than happy with the results Meh. Im getting a cobb intake. I like the noises it makes without getting a loud BOV Link to comment Share on other sites More sharing options...
Akasa Posted December 25, 2014 Share Posted December 25, 2014 Do whatever you please, it's your car. Link to comment Share on other sites More sharing options...
DeltaNu1142 Posted December 25, 2014 Share Posted December 25, 2014 Meh. Im getting a cobb intake. I like the noises it makes without getting a loud BOV Between slow cars that sound fast, and fast cars that sound slow, I'll take the latter. Tits mcgee Link to comment Share on other sites More sharing options...
iNVAR Posted December 26, 2014 Share Posted December 26, 2014 you are not going to get boost creep with a vf40 Link to comment Share on other sites More sharing options...
compsurge Posted December 27, 2014 Share Posted December 27, 2014 I had to LOL at 16psi and the fear that the car was going to explode. That's not boost creep. 14.5+0.8 = 15.3. Close enough to 16. OP, don't worry and don't spend money you don't need to. Link to comment Share on other sites More sharing options...
BoostSLUG Posted December 27, 2014 Share Posted December 27, 2014 Between slow cars that sound fast, and fast cars that sound slow, I'll take the latter. I get what you're saying. But I still want to hear my turbo without making crazy bov noises. I'm not trying to be heard. Link to comment Share on other sites More sharing options...
bkv348 Posted December 27, 2014 Author Share Posted December 27, 2014 you are not going to get boost creep with a vf40 It's s 08 has a vf46, but probably not much of a difference. Link to comment Share on other sites More sharing options...
SleeperScoob Posted December 28, 2014 Share Posted December 28, 2014 The only time you're going to run into bad boost creep is when you have a Cobb OTS tune on a catless downpipe and running an internal wastegate. Even then, its not going to be an enormous detriment to the engine. As long as you aren't targeted @ 17psi, and its creeping to 21-22psi, you'll be fine. Stage 2, it really should not be an issue. If it does happen, deal with it then. If you want to avoid this, run an aftermarket single catted downpipe. Link to comment Share on other sites More sharing options...
iNVAR Posted December 28, 2014 Share Posted December 28, 2014 The only time you're going to run into bad boost creep is when you have a Cobb OTS tune on a catless downpipe and running an internal wastegate. Even then, its not going to be an enormous detriment to the engine. As long as you aren't targeted @ 17psi, and its creeping to 21-22psi, you'll be fine. Stage 2, it really should not be an issue. If it does happen, deal with it then. If you want to avoid this, run an aftermarket single catted downpipe.To the best of my knowledge, no one has ever had boost creep on a stock VF40 or VF46 with any type of exhaust bolted onto it. I don't know why you even mentioned having a Cobb OTS tune. True boost creep is a mechanical problem that can not be corrected with adjustments to a tune. Link to comment Share on other sites More sharing options...
fahr_side Posted December 28, 2014 Share Posted December 28, 2014 To the best of my knowledge, no one has ever had boost creep on a stock VF40 or VF46 with any type of exhaust bolted onto it. I don't know why you even mentioned having a Cobb OTS tune. True boost creep is a mechanical problem that can not be corrected with adjustments to a tune. Exactly. True boost creep is where WGDC has been reduced to zero, either in the initial settings or via intervention via Turbo Dynamics, and still will not stay down at the target boost. This happens because not enough gas is able to bypass the turbine, and instead spins it faster. This in turn is caused by the wastegate flow being insufficient, and is exacerbated by free-flowing turbo-back exhausts. Because the VF-40 and 46 have such tiny turbines, the wastegates are quite generous in size. I've never heard of anyone running into issues with boost creep on these turbos... quite the opposite in fact, people are usually complaining they can't keep it up at higher revs. Install your downpipe, get your protune done, and enjoy. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
SleeperScoob Posted December 28, 2014 Share Posted December 28, 2014 Well, **** me, that's just what I've read from others before. This is why I don't post lol Disregard my cheesery I believe I'm thinking of people who have used certain downpipes that don't allow the wastegate flap to open all the way, in turn producing boost creep. Makes sense to me now. Link to comment Share on other sites More sharing options...
wsmith30132 Posted January 10, 2015 Share Posted January 10, 2015 My new ss-18gxr is having some boost creep issues but my tuner said he could tune around it. It was 10 degrees out the other night and my boost creeped up to 21 psi with my wastegate duty cycle at 0. Is that something where you could just make your target boost that high then drop the timing or whatever majic they do? Definitely don't have the funds for an external wastegate right now. Link to comment Share on other sites More sharing options...
