murphy990 Posted March 9, 2012 Share Posted March 9, 2012 Hi, I have a 2005 lgt limited with 186k on it and when I got my last alignment they said I would need to soon replace a rear wheel bearing I just don't remember what size they had told me. When I drive and am going around a right hand curve or turn the noise is very strong coming from the right. Also when I drive the wheel pulls to the right very badly. I bought the new wheel bearing/hub assembly today from autozone but I need to know hitch one o replace! Any help would e greatly appreciated! Link to comment Share on other sites More sharing options...
vtbimmer Posted March 9, 2012 Share Posted March 9, 2012 If you just had a alignment and your car pulls to the right I would go back and make them do it over. As far as the noisey WB. Put it on the lift and turn the wheel by hand. You should be able to hear/feel it. If not, run it on the lift and have someone stethescope each side. Link to comment Share on other sites More sharing options...
murphy990 Posted March 9, 2012 Author Share Posted March 9, 2012 I had the alignment about 7 months ago, and the noise has been there for about a good 4 months now :/ Link to comment Share on other sites More sharing options...
vtbimmer Posted March 9, 2012 Share Posted March 9, 2012 Should be easy to figure out then. Link to comment Share on other sites More sharing options...
PhilT Posted March 9, 2012 Share Posted March 9, 2012 Replace them both, might as well while you have the tools out. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
adreyna Posted March 9, 2012 Share Posted March 9, 2012 I had the alignment about 7 months ago, and the noise has been there for about a good 4 months now :/ Do what I did, have someone drive your car with the music off and windows up and sit in the back seat so you can hear what side its coming from. Link to comment Share on other sites More sharing options...
Crossing509 Posted March 10, 2012 Share Posted March 10, 2012 Replace them both, might as well while you have the tools out. ^ This. Did mine recently because I thought they were bad. Turns out it was something else. ...Support your LGT community... Link to comment Share on other sites More sharing options...
burnout8488 Posted March 11, 2012 Share Posted March 11, 2012 I'm surprised nobody has mentioned this yet. Drive the car, steer the car hard left and right. When the weight of the car is transferred to the bad bearing, it will usually make more noise. Link to comment Share on other sites More sharing options...
underground000 Posted March 11, 2012 Share Posted March 11, 2012 cant you jack up the car so the wheels are off the ground and 'wobble' each wheel and see which one has more play?? 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
PhilT Posted March 11, 2012 Share Posted March 11, 2012 cant you jack up the car so the wheels are off the ground and 'wobble' each wheel and see which one has more play?? unless the wheel bearing is about to disintegrate, you won't be able to feel any difference. Sent from my Blackberry Playbook using Tapatalk Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
underground000 Posted March 11, 2012 Share Posted March 11, 2012 unless the wheel bearing is about to disintegrate, you won't be able to feel any difference. Sent from my Blackberry Playbook using Tapatalk I'm prob thinking ball joint or something... 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted March 12, 2012 Mega Users Share Posted March 12, 2012 If you just had a alignment and your car pulls to the right I would go back and make them do it over. As far as the noisey WB. Put it on the lift and turn the wheel by hand. You should be able to hear/feel it. If not, run it on the lift and have someone stethescope each side. this has been effective for most, although it wasn't for me. I had a passenger ride in the back seat, and she told me where the noise is coming from the most. It can be tough to distinguish. I took some quick turns left and right on the highway kinda like how they do in nascar to heat up the tires. whatever side that you turn away from that's louder will be your culprit. OP, you have an 05? you should just replace both, the OE bearing hub assemblys on those cars were no good, Im suprised you are just hearing this. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
vtbimmer Posted March 12, 2012 Share Posted March 12, 2012 this has been effective for most, although it wasn't for me. I had a passenger ride in the back seat, and she told me where the noise is coming from the most. It can be tough to distinguish. I took some quick turns left and right on the highway kinda like how they do in nascar to heat up the tires. whatever side that you turn away from that's louder will be your culprit. OP, you have an 05? you should just replace both, the OE bearing hub assemblys on those cars were no good, Im suprised you are just hearing this. Stethescoping from UNDER the car while you are driving at 50 is the only sure way to tell. Ive never not been able to figure out which one is noisey this way. You can also tell if one is starting to go by stethescoping. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted March 13, 2012 Share Posted March 13, 2012 If the bearing is toast there will be play in the wheel. Jack up car. Grab top and bottom of wheel. If there's play, it's toast. Link to comment Share on other sites More sharing options...
PhilT Posted March 13, 2012 Share Posted March 13, 2012 If the bearing is toast there will be play in the wheel. Jack up car. Grab top and bottom of wheel. If there's play, it's toast. If there is play in a wheel bearing it would be undriveable. The noise would be deafening, and the wheel would be very close to falling off. Sent from my Blackberry Playbook using Tapatalk Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted March 13, 2012 Share Posted March 13, 2012 If there is play in a wheel bearing it would be undriveable. The noise would be deafening, and the wheel would be very close to falling off. Sent from my Blackberry Playbook using Tapatalk You have no idea what your talking about. I have had several cars with wheel bearings that had play. They wobbled. They made noise. And they ate tires. I have seen some disintegrate and some that we're rebuildable. Link to comment Share on other sites More sharing options...
PhilT Posted March 13, 2012 Share Posted March 13, 2012 You have no idea what your talking about. I have had several cars with wheel bearings that had play. They wobbled. They made noise. And they ate tires. I have seen some disintegrate and some that we're rebuildable. You are funny. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
cusco-awd Posted March 15, 2012 Share Posted March 15, 2012 I could tell from changing lanes or taking a corner. The noise would come and go depending on how the car was "weighted" in a corner. Link to comment Share on other sites More sharing options...
