Matt166 Posted April 1, 2013 Share Posted April 1, 2013 Looking to see if anyone has a similar symptom. While accelerating I get a breif rattle at low revs - around 1 to 1.5k rpm. Seems to be coming from the middle of the car and only noticeable with the window down. It happens in every gear, so is tied to rpm. However It does not make a noise while the car is revved stationary. My guess is something loose on the clutch plate - any ideas? Link to comment Share on other sites More sharing options...
lesanekusa Posted April 1, 2013 Share Posted April 1, 2013 check your heat shield. Between exhaust pipe and drive shaft.Last time I have a big chunk of ice stuck between shield and drive shaft .From drifting in deep snow LOL. Slide under the car and try to tap the shield.It's wort a try. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 1, 2013 Share Posted April 1, 2013 Looking to see if anyone has a similar symptom. While accelerating I get a breif rattle at low revs - around 1 to 1.5k rpm. Seems to be coming from the middle of the car and only noticeable with the window down. It happens in every gear, so is tied to rpm. However It does not make a noise while the car is revved stationary. My guess is something loose on the clutch plate - any ideas? How many miles on the car? Original clutch ? If it is a more solid "clacking" it is the clutch if it is a more thin sheet of metal rattle could be a heat shield. Link to comment Share on other sites More sharing options...
Matt166 Posted April 1, 2013 Author Share Posted April 1, 2013 150k on car, clutch and gearbox replaced with a new OEM unit by PO at 100k. Its not the usual heat shield rattle I have had on previous cars. Sounds more like a chirpy rattle. The other reason I ruled out the heat shield is that it doesn't happen when the car is stationary. Seeing as a clutch plate will rotate at the same rpm in every gear when the car is actually moving regardless of mph it has me thinking that it may be the cause. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted April 1, 2013 Share Posted April 1, 2013 50K on a stock clutch esp one that sees increased wear can be the death of it... Link to comment Share on other sites More sharing options...
