EMTry53 Posted March 22, 2012 Share Posted March 22, 2012 the areas circled in red is from under my engine, its the exhaust pipe i know that much but the sound is coming from inside it....am i right/wrong? i thought maybe the pipe was either loose or some piece of metal was vibrating, but its REALLY loud first on a cold start, and ALL the time when i accelerate and then let off the gas pedal as well....any ideas, hints, clues? need more info? i tried to take a few landmark pictures so you know exactly where it was located....thanks in advance Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 23, 2012 Share Posted March 23, 2012 Is the noise a hiss, tick, ringing or helicopter like? Link to comment Share on other sites More sharing options...
EMTry53 Posted March 23, 2012 Author Share Posted March 23, 2012 ummm like a loud tin can rattling...like imagine down shifting hard and you hear the engine groan but then add the tin can rattle to the same rhythm and pattern Link to comment Share on other sites More sharing options...
EMTry53 Posted March 23, 2012 Author Share Posted March 23, 2012 here are the sounds i recorded with my phone, they are videos but u can hear the rattling.... http://youtu.be/DFR2tfXvzY4 http://youtu.be/lEQynjy0mqo http://youtu.be/xfPbnwytTsQ Link to comment Share on other sites More sharing options...
cseagle08 Posted March 23, 2012 Share Posted March 23, 2012 I can't watch the vids right now, but all of the heat-shielding around it could be vibrating and making noise. Also check the clearance between the sway bar and the pipe in pic 1....while it is running that is. Link to comment Share on other sites More sharing options...
EMTry53 Posted March 23, 2012 Author Share Posted March 23, 2012 hmm ok ill check that, im almost certain i have located the noise and that its actually inside the heat shielding, but ill double check the clearance, thanks for responding, let me know what you think after you watch the vids... Link to comment Share on other sites More sharing options...
m_dogg Posted March 23, 2012 Share Posted March 23, 2012 Loose heat shield most likely. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 24, 2012 Share Posted March 24, 2012 Yeah that is sound that resonates with engine speed. SOmething is vibrating or touching in that area could be the shielding on the manifold or the cat-pipe.Also have you checked your O2 sensors to make sure they are snug? there is a flange around each and it loose it vibrates quickly against the bung making for a very odd sound. Link to comment Share on other sites More sharing options...
EMTry53 Posted March 24, 2012 Author Share Posted March 24, 2012 hmmmm thanks for the input guys. how accessible is it if I need to check "inside" the heat shield? and which are my 02 sensors? I'm fairly good following directions but don't know exact parts of a cars engine and piping... Link to comment Share on other sites More sharing options...
legacyshawn Posted March 26, 2012 Share Posted March 26, 2012 same exact thing is happening to me. i'll check and see if that's where the sound is coming from on my exhaust. nice videos Link to comment Share on other sites More sharing options...
EMTry53 Posted March 26, 2012 Author Share Posted March 26, 2012 hmmm good to know its not just my car. let me know what you find out as well... Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 26, 2012 Share Posted March 26, 2012 The easiest test is to let your car cool completely (or enough to be able to touch the exhaust) crawl under the passenger side and take a rubber mallet or your fist and bang the cat pipe. This is how I found my rattle coming from around the second catalytic converter. The insulation btwn the pipe and shield breaks down and when it does the shielding rattles driving the owner INSANE Link to comment Share on other sites More sharing options...
EMTry53 Posted March 26, 2012 Author Share Posted March 26, 2012 Hahahahaha ok....so IF I end up doing that lol, what's the fix? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 26, 2012 Share Posted March 26, 2012 Hahahahaha ok....so IF I end up doing that lol, what's the fix? Take the shielding off. lol Link to comment Share on other sites More sharing options...
EMTry53 Posted March 26, 2012 Author Share Posted March 26, 2012 Hahahahaha and that's the "silver-ish" looking crap circled in red on the first picture I posted? Link to comment Share on other sites More sharing options...
cseagle08 Posted March 27, 2012 Share Posted March 27, 2012 Hahahahaha and that's the "silver-ish" looking crap circled in red on the first picture I posted? Yup Link to comment Share on other sites More sharing options...
m_dogg Posted March 27, 2012 Share Posted March 27, 2012 On my old car, I was tracking a rattle just like that. One day I got fed up with it and took all of the heat shields off - problem solved. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 28, 2012 Share Posted March 28, 2012 Hahahahaha and that's the "silver-ish" looking crap circled in red on the first picture I posted? http://fwtc.files.wordpress.com/2010/11/crank_yankers_yay-737929.jpg?w=300&h=240 Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 28, 2012 Share Posted March 28, 2012 hahahaha yeah man also a thing to note is that the bolts will probably be rusted to hell or just suck. I suggest trying it with a socket/wrench first then if that fails employ a hacksaw or cutoff wheel If you have neither tools nor know-how a shop could remove the shielding for you for cheap . Link to comment Share on other sites More sharing options...
EMTry53 Posted March 28, 2012 Author Share Posted March 28, 2012 thanks guys for the input. a friend said there could be fuel lines or power steering lines near the heat shield and it prefenvts it from boiling, Is this true or can I just remove the shield for good ? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 28, 2012 Share Posted March 28, 2012 thanks guys for the input. a friend said there could be fuel lines or power steering lines near the heat shield and it prefenvts it from boiling, Is this true or can I just remove the shield for good ? NO your PS lines are shielded and too far away for the cat pipe to boil the fluid. Your Fuel lines aren't on that side of your car so no worries there. You could also take the shielding off and wrap thermo wrap around the area closest to the PS rack for peace of mind:) Link to comment Share on other sites More sharing options...
EMTry53 Posted March 28, 2012 Author Share Posted March 28, 2012 thanks! works for me! when I get a sunny warm day in the next week or two ill be doing this...pics to come...thanks fellas Link to comment Share on other sites More sharing options...
legacyshawn Posted March 29, 2012 Share Posted March 29, 2012 I didn't have much time today but I got under to take a look. Ended up taking a drill and drilled through the head of a rusted screw and popped it off. Most of the rattle is coming from the passenger side of the header. For now I just once piece of the exhaust pipe exposed; wanted to do some more reading before I got too frenzy with the whole removal. But MOST of the rattling noise is gone! woohooo! Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 29, 2012 Share Posted March 29, 2012 I didn't have much time today but I got under to take a look. Ended up taking a drill and drilled through the head of a rusted screw and popped it off. Most of the rattle is coming from the passenger side of the header. For now I just once piece of the exhaust pipe exposed; wanted to do some more reading before I got too frenzy with the whole removal. But MOST of the rattling noise is gone! woohooo! You can safely remove ALL of the manifold shielding and the cat pipe shielding. Link to comment Share on other sites More sharing options...
EMTry53 Posted March 30, 2012 Author Share Posted March 30, 2012 ok so I'm unable to remove the bolts right this second, but I found that apparently I bottomed out and cracked the plastic shit under the car plus it distorted the heat shield ever sl slightly so that's why it's rattling. I found that the rattle is where the joint of the shield meets at the very first part when it starts to the rear of the car....pics to come, but now my question is, is there any "temporary" fix with some sort of rubber to wedge between the two at the joint? any heat resistant material that isn't metal, for obvious reasons? Link to comment Share on other sites More sharing options...
