anthonyr Posted March 27, 2010 Share Posted March 27, 2010 So I want to install these L.E.D puddle lights under each door. Anyone know of an easy power source so I can get the brightening and dimming effect with the courtesy lights not the constant on effect? Thanks in advance. Link to comment Share on other sites More sharing options...
Hanger Posted April 2, 2010 Share Posted April 2, 2010 +1 interested in knowing this as well ○ ○ ○ Instagram: itshangertime :spin: ○ ○ ○ Link to comment Share on other sites More sharing options...
AkumaMax Posted April 5, 2010 Share Posted April 5, 2010 hmmm I would think you need to tie them into the interior light that goes one when you unlock your car. You would have to have a long wire to go from outside the car to the interior of your car. Link to comment Share on other sites More sharing options...
bigdadi Posted April 5, 2010 Share Posted April 5, 2010 2010 Puddle Lamp Kit Installation ... scroll down. http://techinfo.subaru.com/html/ixSearchFree.jsp?publication_type=12&text_keyword=&keyword=&free_pub=13 Link to comment Share on other sites More sharing options...
Peaty Posted May 19, 2010 Share Posted May 19, 2010 I did the puddle light install the other week, the OEM one. You do get the slight dimming effect with the OEM ones. They don't just turn off abruptly, but they do dim quickly. The thing is finding the OEM harness was a bugger on the passenger side. At first I thought it wasn't even there. It took quite a bit of searching to find it it was so tucked up in there and hidden. To get to it they do show you to drop the wheel well lining (which I did) however, the graphic in the install manual is very deceiving. The plug on the passenger side is pretty much up under the intake's airbox. I had to remove the airbox to get to the tape that was holding the plug harness in place. You can identify the harness by the pale red / almost washed out pink colored tape holding it in place. On the drivers side (LHD) it was easier to find but in the same general vicinity, more up towards the headlamp direction and the same type of tape holding it in place. The end of each plug has a protective cap you need to remove before plugging in the OEM harness. Hope that helps some for anyone looking for the plugs. The OEM install was very simple and did not take too long, it was just finding the OEM harness plugs that threw me for a while. Peaty, 2019 Imp Sport 5 Dr (Mine) 2013 Outback Premium (Wife's) 2010 Legacy 3.6R (Son), 2001 Forester S (other son) 1999 Miata (my summer ride) Link to comment Share on other sites More sharing options...
UK2TX2CA Posted January 22, 2011 Share Posted January 22, 2011 ... The plug on the passenger side is pretty much up under the intake's airbox. I had to remove the airbox to get to the tape that was holding the plug harness in place. You can identify the harness by the pale red / almost washed out pink colored tape holding it in place. .... Hope that helps some for anyone looking for the plugs. ..... Thank you so much for posting this, spent ages looking for the plug on the passenger side so searched here to see if anyone else had a car without one Link to comment Share on other sites More sharing options...
Peaty Posted January 22, 2011 Share Posted January 22, 2011 Glad it helped, I know what you mean. I had everything apart and looked and looked. I started to panic thinking it wasn't on my car! Peaty, 2019 Imp Sport 5 Dr (Mine) 2013 Outback Premium (Wife's) 2010 Legacy 3.6R (Son), 2001 Forester S (other son) 1999 Miata (my summer ride) Link to comment Share on other sites More sharing options...
SBT Posted January 29, 2011 Share Posted January 29, 2011 So is this only for the 2010+ models or do the 4th Gens also have this plug & play capability? Think that was part of the OP's question. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Peaty Posted January 30, 2011 Share Posted January 30, 2011 The OP didn't say what year and his profile does not list a car. I believe they were only offered for the 10+ MY so I assumed (possibly wrongly) that the car in question was a 5th gen. I have seen a few people do retrofits on other MY's for different scoobies. That was one of the reasons I took detailed dimensions on just the lamps. Someone wanted to know to see if they could fit them in a different year. I have that info here: http://www.scoobymods.com/puddle-light-install-t6648.html and the lamps themselves are the same for the Tribeca and the Legacy I know for sure because I've had my hands on both. Peaty, 2019 Imp Sport 5 Dr (Mine) 2013 Outback Premium (Wife's) 2010 Legacy 3.6R (Son), 2001 Forester S (other son) 1999 Miata (my summer ride) Link to comment Share on other sites More sharing options...
LegGT24 Posted May 23, 2011 Share Posted May 23, 2011 Interested in installing these on a 4'th gen Legacy. Since there is not a harness located in the fender, how difficult would it be to tie them into the wiring for the dome light? Is there a wiring diagram available that would make the install easier? Link to comment Share on other sites More sharing options...
Zephrant Posted June 14, 2011 Share Posted June 14, 2011 That's something I'd like to try too. $115 or so for the kit, then I've got to find my own wires. I assume I could find the dome light power in the fuse cluster someplace... Link to comment Share on other sites More sharing options...
DeeperImage Posted January 6, 2013 Share Posted January 6, 2013 I'm bout to order one of these OEM kits and was wondering where you actually mount the lights underneath? are there holes or brackets? Thanks for the info. Link to comment Share on other sites More sharing options...
Peaty Posted January 6, 2013 Share Posted January 6, 2013 http://www.scoobymods.com/showthread.php/puddle-light-install-6648.html that links shows an install basically the same on the legacy I did. You need to register to see the pics but it's free. Peaty, 2019 Imp Sport 5 Dr (Mine) 2013 Outback Premium (Wife's) 2010 Legacy 3.6R (Son), 2001 Forester S (other son) 1999 Miata (my summer ride) Link to comment Share on other sites More sharing options...
famaya26 Posted January 6, 2013 Share Posted January 6, 2013 Didn't Subaru just recall a whole bunch of cars because of the puddle lights? Link to comment Share on other sites More sharing options...
