AZP Installs Posted May 30, 2012 Share Posted May 30, 2012 Darn, thought you might have found a sponsor. If we were only that lucky. We may actually attempt to enter a continental tire grand am race with it if we pull it off. Mike Link to comment Share on other sites More sharing options...
m sprank Posted May 30, 2012 Share Posted May 30, 2012 Good luck! Sounds like a ton of fun. Link to comment Share on other sites More sharing options...
sjwelna Posted June 13, 2012 Share Posted June 13, 2012 Posted this in another thread, but I knocked out the Koni/Epics on my car last night after work. Only took me about 4-5 hours including taking a break between front/back for dinner. All my bolts surrendered to my Makita cordless impact easily so I think I got lucky, everything went back together with anti-seize for the future. So far the quick impression is great, good bye lift/dive! Link to comment Share on other sites More sharing options...
famaya26 Posted July 18, 2012 Share Posted July 18, 2012 Ok guys, I'm buying some Konis next year to lower my legacy. Was going to use GR2's but after reading and searching I found the Konis are the best route to go. I'm going with some H-Tech Springs. Might consider the Epics but that can wait right now. My question though, for a noob at working on cars, how hard would you rate this job? I read the walkthrough and it seems complicated. Link to comment Share on other sites More sharing options...
Underdog Posted July 18, 2012 Share Posted July 18, 2012 That is going to be very tough to answer for you specifically. Do you have all the tools listed in the walkthrough? The Crimson Dynamo Link to comment Share on other sites More sharing options...
famaya26 Posted July 18, 2012 Share Posted July 18, 2012 My dad is a truck driver. He Should have the tools since he does his own maintenance and also works on other peoples trucks. So yes. Link to comment Share on other sites More sharing options...
Underdog Posted July 18, 2012 Share Posted July 18, 2012 Then you should ask your Dad. It's not overly complicated, just take your time, and follow the very thorough instructions posted here. The Crimson Dynamo Link to comment Share on other sites More sharing options...
famaya26 Posted July 18, 2012 Share Posted July 18, 2012 Alright then will do. The thing that makes me nervous is the cutting. I'll thouroughly read the walkthrough and when the time comes at get to it. Link to comment Share on other sites More sharing options...
m sprank Posted July 18, 2012 Share Posted July 18, 2012 Hi Rick, have not seen you round these parts for a bit. Then you should ask your Dad. Good advice. Link to comment Share on other sites More sharing options...
Underdog Posted July 18, 2012 Share Posted July 18, 2012 Measure twice, cut once. If you don't want to use the hacksaw then use the pipe cutter that msprank linked to, a couple posts down from the OP. *edit* Hey Mike. Been lurking mostly... trying to save my money for equipment rather than just parts. The Crimson Dynamo Link to comment Share on other sites More sharing options...
famaya26 Posted July 18, 2012 Share Posted July 18, 2012 Yea I read that. Def going to use that. Link to comment Share on other sites More sharing options...
Casezilla Posted August 20, 2012 Share Posted August 20, 2012 How are you guys torquing the strut top nut on the rears in a sedan? The fronts were no problem with a thru ratchet and a 9mm deep socket on a 3/8" drive ratchet, but in rears, the hole in the bottom of the trunk that provides access to the nut doesn't allow any room for ratcheting with the standard 19mm thru socket. I can get the socket on the nut, but the trunk body blocks any horizontal movement of the ratchet. My thru socket set has a socket extension (~2") which provides enough clearance to ratchet, but that creates 2 problems. First, the socket+extension on the thru ratchet is longer than my deep sockets, so I can no longer reach the inner nut. Second, even if the length wasn't a problem, the 9mm socket expands at the end to fit the 3/8" drive connector, and at the point where the socket expands, it no longer fits through the 19mm thru socket. That means adding an extension to the 9mm deep socket isn't an option. What are my options here and what have you guys been doing? I'm thinking I'll have to get a 1/4" drive 9mm deep socket and a 1/4" drive socket extension. It seems like that would work as long as the extension stays slim enough to fit through the thru sockets. Link to comment Share on other sites More sharing options...
compsurge Posted August 20, 2012 Share Posted August 20, 2012 (edited) I assume the car is on the ground? I used a torque wrench on the inner and one of those special kobalt/craftsman socket sets with the external thru-drive to tighten the nut against the torque wrench. I only had issue on the fronts, go figure. Have you tried just torquing the nut without holding the center in place? I didn't hold the rear in place while torquing mine. Edited August 20, 2012 by compsurge Link to comment Share on other sites More sharing options...
m sprank Posted August 21, 2012 Share Posted August 21, 2012 Do it before install. Or, cut a small portion of the metal out and make the circle hole larger. Much easier to do prior to install. Link to comment Share on other sites More sharing options...
dan04103 Posted August 21, 2012 Share Posted August 21, 2012 (edited) Thanks for the install walkthrough. I just put a set on my lowered outback and were just what the doctor ordered. I now have my eurowagon look/feel. Only problem I ran into was the shaft going limp on me while trying to install the tophat LOL! Other than that was a breeze. Running right now at 1 turn from soft and I think I might go another 1/4 to 1/2 turn as once the struts settle in it they will probably soften a touch. Edited August 21, 2012 by dan04103 Link to comment Share on other sites More sharing options...
dingbang Posted August 23, 2012 Share Posted August 23, 2012 I was able to torque mine down with the wheels on the ground without a problem. Getting those rears off was a pita, my electric impact didn't budge em Took brute strength, pb blaster, and lots of yelling and swearing to break the bolts loose. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted August 24, 2012 Share Posted August 24, 2012 I could just reuse all these parts off my stock strut, right ?Or do I have to replace any of them with new ? B) OEM dust cover (P/N 20322AG00A, qty.1/side) C) OEM top mount (P/N 20320AG00A, qty.1/side) E) OEM bump stop (P/N 20321AA201, qty.1/side) F) OEM conical washer (P/N 20326AA000, qty.1/side) G) OEM upper spring seat (P/N 20323AG00A, qty.1/side) Link to comment Share on other sites More sharing options...
Underdog Posted August 24, 2012 Share Posted August 24, 2012 You can reuse them all. The only one that really wears out is "C", the top mount. It has a bearing in it that gets beat up, especially if you had been on lowering springs. The Crimson Dynamo Link to comment Share on other sites More sharing options...
ibr_adam09 Posted August 24, 2012 Share Posted August 24, 2012 Nope I'm completely stock. Other than C. I just need to get the Koni kit and be all set ? Any other tips or guides people learned from this install. I keep reading people having trouble tightening down the top strut bolts ? why ? Link to comment Share on other sites More sharing options...
ibr_adam09 Posted August 24, 2012 Share Posted August 24, 2012 THMotorsports has a full set for $490 shipped with promo code taxbreak2010 ( yep still works ) now looking into springs . Might go with H & R Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 24, 2012 I Donated Share Posted August 24, 2012 THMotorsports has a full set for $490 shipped with promo code taxbreak2010 ( yep still works ) now looking into springs . Might go with H & R Go with the epics! gb opening soon... Link to comment Share on other sites More sharing options...
Max Capacity Posted August 24, 2012 Share Posted August 24, 2012 I see that promo code still works, I just placed an order. Thanks 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ibr_adam09 Posted August 24, 2012 Share Posted August 24, 2012 Go with the epics! gb opening soon... I was looking to go a tad lower than the epics. but I dunnnnnoooooo shit bout springs/ brands. Max, I tried to use taxbreak 2011 and 2012 too, didn't work Link to comment Share on other sites More sharing options...
compsurge Posted August 24, 2012 Share Posted August 24, 2012 They probably caught on after he ordered and he'll find it canceled XD Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 24, 2012 I Donated Share Posted August 24, 2012 I was looking to go a tad lower than the epics. but I dunnnnnoooooo shit bout springs/ brands. Max, I tried to use taxbreak 2011 and 2012 too, didn't work Here's a good guide someone posted in the epic GB thread: http://legacygt.com/forums/showpost.php?p=2627431&postcount=19 Gives you a good idea of what springs offer what kind of drop, spring rates etc. Link to comment Share on other sites More sharing options...
