SubieAA Posted February 7, 2015 Share Posted February 7, 2015 Second time in quick succession the ABS engaged in hard braking in stop and go traffic on completely dry surface and new tires. I plan to disengage it but has anyone appealed a surcharge due to this problem? Link to comment Share on other sites More sharing options...
bluesuby Posted February 7, 2015 Share Posted February 7, 2015 Isn't that what ABS is supposed to do? Keep wheels from locking up when brakes are applied with a lot of force? Surcharge? You get a "discount" for having ABS. Link to comment Share on other sites More sharing options...
SubieAA Posted February 7, 2015 Author Share Posted February 7, 2015 Unfortunately it engages when that is not the danger effectively making your stopping range much longer. Link to comment Share on other sites More sharing options...
Underdog Posted February 7, 2015 Share Posted February 7, 2015 I think you should appeal it but know that your position is basically indefensible. If the car was malfunctioning then the burden is on you as the owner for driving an unsafe vehicle, looking at it from the magistrate's perspective. If the car was not malfunctioning - and indeed it will be impossible for you to prove it was - then they will chalk it up to the speed/distance you were driving. New tires are usually a bit slick due to the mold release compound they use. Also - Boston is a mess right now; what type of tires did you go with? The Crimson Dynamo Link to comment Share on other sites More sharing options...
SubieAA Posted February 7, 2015 Author Share Posted February 7, 2015 Thanks. There were three cars. The one in front if me stopped in time, but my ABS went on, in a dry tunnel, until I had to try to negotiate around him without room. It was like air in your brakes. The light signaling a problem with my ABS not on. It literally felt like no brakes and I was not going that fast. I will have to make the case. Link to comment Share on other sites More sharing options...
apexi Posted February 7, 2015 Share Posted February 7, 2015 How many miles on the tires? New tires can have really poor traction until they're worn down a little. Link to comment Share on other sites More sharing options...
Merc6 Posted February 8, 2015 Share Posted February 8, 2015 Yeah about 500 miles or so to burn of whatever it's coated in to not stick to the tire mold. ABS on my other car kicks in if you hit a bump in the road while braking. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Leviman Posted February 8, 2015 Share Posted February 8, 2015 It could be that you have a bad wheel bearing, causing the wheel's reluctor wheel to signal a spike which triggers the ABS. Never heard of this in a Subaru, but I've seen it first hand on 4wd Chevy trucks (which have similar hub assembly style wheel bearings). Link to comment Share on other sites More sharing options...
