milesej05 Posted April 15, 2011 Share Posted April 15, 2011 Here's the deal. I would say once every 3 days while I'm driving I will shift either from 2nd to 3rd or from 3rd to 4th and let off the clutch and push the gas in like normal but I will feel the car like bog down and lose a little power but then the power (turbo?) kicks back in and back to normal. Won't happen again for, like I said, about 3 days. Usually happens within the first 3 miles of driving my car (normally in the mornings when I'm leaving work or at night, midnight, when I'm heading to work). As I am new to the turbo world, is this normal or something to be checked out. I would assume its normal as I don't here any unusual noises and all my gauges read normal (MPG gauge and Tach). Any insight would be helpful Info on car: only have muffler delete and AVO panel filter. No tune. Link to comment Share on other sites More sharing options...
Gire Posted April 15, 2011 Share Posted April 15, 2011 You are likely experinecing the studder that these cars often have. Usually happens between 2K - 3K and you are on the gas accelerating. It studders and isn't really smooth. We have been suffering from this since 2005 when the model was new. A tune will help smooth it out, if you get a protune map emailed to you, or even better, road or dyno tuned. A good tuner can help smooth it out, even in a stage 1 map that keeps your OEM catted down pipe in place. Link to comment Share on other sites More sharing options...
milesej05 Posted April 16, 2011 Author Share Posted April 16, 2011 Awesome, I kinda figured it was a problem with all the LGT's. The guys over on Nebraska-Subaru.com (most of which own WRX's) thought it might be a problem and to get it tuned asap...so I came over here. Its at the point just where the turbo would MOST LIKELY kick into full gear. But thank you Gire...will try and get a tune/accessport after I get a new DP. Cheers for the weekend!! Link to comment Share on other sites More sharing options...
