T_Altland27 Posted April 5, 2014 Share Posted April 5, 2014 I know you can adjust the lights up and down but can you adjust them from side to side at all in our 09 legacies I put the hid bulbs in a little while ago and to me they aren't aimed right the driver side needs to move to the right a little bit and the passenger side isn't to bad or maybe if there isn't a left to right adjuster then maybe I can tweak the bulb a little bit and help would be greatly appreciated Link to comment Share on other sites More sharing options...
chutoyy Posted April 5, 2014 Share Posted April 5, 2014 If it's like the 05, there is a horizontal adjustment screw... Its under a cap to prevent people from adjusting it at the 10-11 o'clock position looking at the back of the low beam cover... You should be able to access it without taking the headlight off... but it may be easier to take it off on the driver's side. Edit: Don't tweak the bulb because it will ruin the focus of the projector and will ruin the light output. Link to comment Share on other sites More sharing options...
mr.hicksta Posted April 5, 2014 Share Posted April 5, 2014 http://legacygt.com/forums/showthread.php/align-your-headlights-if-you-dont-know-now-you-do-54740.html Link to comment Share on other sites More sharing options...
T_Altland27 Posted April 5, 2014 Author Share Posted April 5, 2014 Ok thanks Link to comment Share on other sites More sharing options...
