driving Posted June 18, 2013 Share Posted June 18, 2013 I have been checking for weeks and have found no info on these springs? I have Eibachs and have been bouncing off the bump stops. These are the only springs i've known they came on the car. I have a set of spec b springs ready to go in. But like to know what I'm getting into before i spend the time and money... Link to comment Share on other sites More sharing options...
idiot4hire Posted June 18, 2013 Share Posted June 18, 2013 They are very similar if not the same as stock gt. Eibachs match well with kyb oem replacement Link to comment Share on other sites More sharing options...
driving Posted June 18, 2013 Author Share Posted June 18, 2013 The Eibachs blew out my KYB's in less than 30K. Im hoping that the kyb's will last longer with a bit more travel on the spec b springs. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted June 19, 2013 Share Posted June 19, 2013 The kyb's are an oem replacement, and are valved as such. The specB springs are the same rates as the oem lgt springs AFAIK, and therefore they should match. Anything stiffer than oem springs will burn through a set of kyb's in short order. Link to comment Share on other sites More sharing options...
driving Posted June 19, 2013 Author Share Posted June 19, 2013 thanks for all the reply's just wish i could go for a ride in a stock spec b (i know shock will be different) I test drove one LGT before i bought mine but don't recall the ride but ride height was similar to my car. It took me a full min to realize my LGT was lowered. I like the ride of my wifes G6 but has like 5 inches of wheel gap not my cup of tea. Link to comment Share on other sites More sharing options...
Totaled04Rex Posted June 19, 2013 Share Posted June 19, 2013 The eibachs on my old accord were so bad that they sagged and I couldn't install a camber kit. I will never use another eibach product because of this. Junk IMO Link to comment Share on other sites More sharing options...
iNVAR Posted June 20, 2013 Share Posted June 20, 2013 eibachs/epics are about 1" lower all around and stiffer. dampers that are meant to go with stock ride height and stiffness (aka. the kyb gr2) are not dampened enough. Link to comment Share on other sites More sharing options...
driving Posted June 26, 2013 Author Share Posted June 26, 2013 Well bolted up the spec b and kybs last week. So far great ride. Takes the bumps and potholes the way a suspension should. Still have a sagging left rear must be that wornout joint the subaru dealer said was due to be replaced. Anywho great ride this stock set up. Sure a bigger rear bar would help but one thing at a time. Ill post pics when i get a chance so others can see what a spec b Kyb set up looks like. And if anyone comes across the spring rates for the spec b springs post em here. thanks Link to comment Share on other sites More sharing options...
idiot4hire Posted June 26, 2013 Share Posted June 26, 2013 The kyb's are an oem replacement, and are valved as such. The specB springs are the same rates as the oem lgt springs AFAIK, and therefore they should match. Anything stiffer than oem springs will burn through a set of kyb's in short order. eibachs/epics are about 1" lower all around and stiffer. dampers that are meant to go with stock ride height and stiffness (aka. the kyb gr2) are not dampened enough. alright I was wrong, I thought I read that some where Link to comment Share on other sites More sharing options...
