poohbear36 Posted April 8, 2011 Share Posted April 8, 2011 My sister's legacy 2.5L non turbo engine started knocking and the engine needs replacing. She told me she checked the oil and it would read low, she would add oil and then the dipstick would read overfilled. When the mechanic took the pan off, he said there was no oil in the oil pan and the car has no leaks anywhere. Has anyone had a similar problem with this particular model and engine since it was only made for one year. I need help right away on this so any information would be very much appreciated. It is going to cost over $6,000 to repair. Thank you. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted April 8, 2011 Share Posted April 8, 2011 $6000 for a new engine seems kinda steep. How confident are you in your sister's maintainance story? Not accusing her of anything, but it sounds like she ran the engine out of oil. Link to comment Share on other sites More sharing options...
needcoffee Posted April 8, 2011 Share Posted April 8, 2011 Have an '07 2.5i in the shop right now for a simlar reason. Nothing leaking. No residue anywher on or around the engine. Nothing on the driveway. Nothing on the ground at my spot at work. No grey in the tailpipes. OIC always at or less than 3750 miles since I bought it. I have only owned it for half of its milage. Current status: Oil Pump - Shot Oil Pickup - Shot SHORT BLOCK - SHOT If the stealership is putting in a whole new engine then the price is not too far off. Depends on what they charge for labor and what they are reusing from the 1st motor. Just saying her story could definitely be legit. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted April 9, 2011 Share Posted April 9, 2011 I'm not a mechanic so can someone explain how a blown oil pump would cause an engine to have no oil in the pan? Link to comment Share on other sites More sharing options...
Osei Posted April 9, 2011 Share Posted April 9, 2011 You can buy a used 2.5 (06-08)$1800-2100. Another 800-1000 to pull old and swap new. Shop around and find a mechanic who will do it reasonably. O. Link to comment Share on other sites More sharing options...
poohbear36 Posted April 9, 2011 Author Share Posted April 9, 2011 Thanks everyone for your info. I was a mechanic for over 12 years and I found out from the shop that my sister did run it dry and hadn't changed the oil since last october. That is why the pan was dry. I will try to find a used engine at a reasonable price. Link to comment Share on other sites More sharing options...
Ari_OutbackWagon Posted May 2, 2011 Share Posted May 2, 2011 Same story here. Original owner, 2007 Outback 2.5i, started knocking at 112,000 miles. Thing has burned oil since new and knowing this, I kept on top of it. I've had other cars that burn oil, but they're usually German and I expect that. I'll never buy another Subaru again. POS. Link to comment Share on other sites More sharing options...
