digdug18 Posted June 1, 2015 Share Posted June 1, 2015 Is their any difference between headlights that have the turn signal attached, vs those that the headlight and turn signal are 2 separate pieces? I ask because I'm putting in HID projector's, just trying to get the better option. They both look equally as clear, and not really much of a difference. Is one easier to aim, adjust, install? Andrew Link to comment Share on other sites More sharing options...
Zues Marine Posted June 1, 2015 Share Posted June 1, 2015 yeah they are pretty much the same.. the one piece being a bit more common on the earlier models Link to comment Share on other sites More sharing options...
elislider Posted July 1, 2015 Share Posted July 1, 2015 Is their any difference between headlights that have the turn signal attached, vs those that the headlight and turn signal are 2 separate pieces? I ask because I'm putting in HID projector's, just trying to get the better option. They both look equally as clear, and not really much of a difference. Is one easier to aim, adjust, install? Andrew you should not install HIDs in the stock reflector-style headlights. Instead you should buy the JDM 2nd gen headlights that have a projector lens which is much more appropriate for HIDs Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 1, 2015 Share Posted July 1, 2015 ^And then do the conversion to the USDM light pattern for best results. You can aim them pretty low but it's not the ideal way to do it. But I don't see anything wrong with installing HID projectors in your existing headlights. Morimoto makes some awesome sets: http://www.theretrofitsource.com/complete-retrofit-kits/bi-xenon-morimoto-mini-stage-3-kit-h1.html#.VZPsZvlVi84 Link to comment Share on other sites More sharing options...
