Coolbs7 Posted December 16, 2013 Share Posted December 16, 2013 I was out having some fun in the snow last night and whatnot, and then I came to a stop and needed to launch, but I wasn't able to put my car into first gear. All the other gears are fine - any thoughts on what the issue could be? Link to comment Share on other sites More sharing options...
Turkeylord Posted December 16, 2013 Share Posted December 16, 2013 I've had the same issue and been told not to worry about it too much... <shrug> Try working the shifter through the other gears and see f it loosens up. Link to comment Share on other sites More sharing options...
rob-2 Posted December 16, 2013 Share Posted December 16, 2013 Syncro might be gone Link to comment Share on other sites More sharing options...
subie3429 Posted December 16, 2013 Share Posted December 16, 2013 Same thing happened to me in the snow in my 06. Syncro was gone and needed replaced. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 16, 2013 Share Posted December 16, 2013 I was out having some fun in the snow last night and whatnot, and then I came to a stop and needed to launch, but I wasn't able to put my car into first gear. All the other gears are fine - any thoughts on what the issue could be? Contact "underdog" he may be able to help with the rebuild. He's in your area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
andyengineer Posted December 17, 2013 Share Posted December 17, 2013 I've always had some intermittent issues with first and reverse in just about every car. If I just put it in neutral, let off on the clutch, then try again it goes in. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 17, 2013 Share Posted December 17, 2013 That's how most mt work, they are not perfect every time. Had to double clutch the wagon to get in revese the other day. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
wireless007 Posted December 18, 2013 Share Posted December 18, 2013 Check the linkage underneath to make sure nothing is stuck in it or binding it up. You can see it all from underneath right above the dive line. Have someone go through the gears and see if you notice anything. After installing my short throw shifter and new bushings, I had to grind off the little hook on the big pivot bushing washer because it was rubbing my first gear shift, even preventing it sometimes. The"spring retainer" hook is UN necessary on our cars anyway. Link to comment Share on other sites More sharing options...
Coolbs7 Posted December 18, 2013 Author Share Posted December 18, 2013 Turns out the shifter is broken inside my tranny. All the gears stopped working Link to comment Share on other sites More sharing options...
Turkeylord Posted December 18, 2013 Share Posted December 18, 2013 Ouch, sorry to hear that Link to comment Share on other sites More sharing options...
Max Capacity Posted December 18, 2013 Share Posted December 18, 2013 PM underdog, he may know of a good tranny guy. My guy is in windsor locks CT If you can pull the tranny, the shift forks are about $160 for the 3 of them. Plus what ever else needs replacing while it s apart. Figure at least $300 for tranny parts. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 19, 2013 Share Posted December 19, 2013 I'm thinking this won't call for a rebuild. I bent the shifter forks in a tranny once and although a couple hundred bucks it was a lot better than $1,000. I was horsing around when it happened too. As for having trouble shifting into 1st or Reverse. Have a look on Wiki how trannies work and you'll see why that is. On a BW I had years ago, I had to shift into 5fth first before going into Reverse if I didn't want to buzz my hand. Maybe try this strategy. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 20, 2013 Share Posted December 20, 2013 If all else fails, check this thread out: http://legacygt.com/forums/showthread.php/fs-va-5mt-transmission-05-obxt-4-44-final-drive-218006.html You don't need everything he is selling though. Seller may give you a deal. In any case, he is legit and a very good guy. Link to comment Share on other sites More sharing options...
