Scoobysnax22 Posted July 27, 2015 Share Posted July 27, 2015 So after I got my car all put back together after doing my clutch, I noticed an opening on the top of the very back of my engine, passengers side underneath the intercooler. It's about the same size as the hole for the clutch fork on top of the bell housing and also in a similar location but in pretty sure it's on the engine side. You can look down it and see your flywheel. Both me and my mechanic buddy thought it was weird that its there and not covered with some sorta boot or something. I feel like so much dirt and dust could get down there and ruin my brand new clutch. Does anyone know if there is supposed to be a boot covering this hole? Link to comment Share on other sites More sharing options...
GTEASER Posted July 27, 2015 Share Posted July 27, 2015 If you're worried about a little dirt and dust ruining your new clutch that's made out of steel, weighs 30 pounds and spins at 5k rpms, you should lock yourself in your house now and never come out. That hole is normal and there is no rubber boot or plate that goes over it. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Harsho1 Posted July 27, 2015 Share Posted July 27, 2015 that is where you used to use a timing light to set timing on subarus when they had distributors. There should be a plug there. Link to comment Share on other sites More sharing options...
GTEASER Posted July 27, 2015 Share Posted July 27, 2015 that is where you used to use a timing light to set timing on subarus when they had distributors. There should be a plug there. Well, I just learned something new today. Thanks!! Never looked down there on my 2012, and my 1992 doesn't have one, I can see the flywheel, so I guess I just assumed. OP, you need a timing hole plug. This part number should do it. http://parts.cioccasubaru.com/p/Subaru__/PLUG-TIMING-HOLE/49223646/11413AA033.html GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Scoobysnax22 Posted July 27, 2015 Author Share Posted July 27, 2015 So I guess if dirt and dust can't ruin my new clutch I shouldn't have bothered cleaning the flywheel and pressure plate thoroughly with brake cleaner before I installed it...I'm pretty sure dirt and dust can absolutely **** a clutch Link to comment Share on other sites More sharing options...
mondtster Posted July 27, 2015 Share Posted July 27, 2015 So I guess if dirt and dust can't ruin my new clutch I shouldn't have bothered cleaning the flywheel and pressure plate thoroughly with brake cleaner before I installed it...I'm pretty sure dirt and dust can absolutely **** a clutch If that were true, the clutch dust that gets generated would destroy the clutch itself. I'd be more worried about not having the plug in the hole because it will allow all the clutch dust to escape and make a mess. I haven't had to do much work on the automatic transmission Subarus, but I've always assumed the hole was there to provide easy access for the flexplate bolts to be removed. Link to comment Share on other sites More sharing options...
GTEASER Posted July 27, 2015 Share Posted July 27, 2015 So I guess if dirt and dust can't ruin my new clutch I shouldn't have bothered cleaning the flywheel and pressure plate thoroughly with brake cleaner before I installed it...I'm pretty sure dirt and dust can absolutely **** a clutch Pretty sure gravel, stones or a dropped bolt might **** your shiny new clutch, but dust, probably not because it makes its own dust as it wears, and as you know, it's dirtier than a whore's taco hammock in there. You're welcome for the part number. You probably didn't need to clean the flywheel, but you should have resurfaced it and the machine shop would have cleaned it for you. And why would you clean a new pressure plate? Oh, you only replaced the disc? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted July 27, 2015 Share Posted July 27, 2015 Throw a piece of duct tape over the whole and move on. Or go to the dealer and order the rubber plug that belongs in the hole. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scoobysnax22 Posted July 27, 2015 Author Share Posted July 27, 2015 Nah I got a whole new clutch kit. Exedy stage 1 with single mass flywheel. Thanks for the help dewds Link to comment Share on other sites More sharing options...
Mike07LGT Posted July 28, 2015 Share Posted July 28, 2015 Nah I got a whole new clutch kit. Exedy stage 1 with single mass flywheel. Thanks for the help dewds where did you order the clutch from? good price? im getting ready to buy a new one for my car and im trying to find a good deal thanks! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Scoobysnax22 Posted July 28, 2015 Author Share Posted July 28, 2015 I actually got it from a guy off here! Got a good deal on it $600 for the whole kit: exedy stage one with single mass flywheel and he also threw in a ground and tranny mount Link to comment Share on other sites More sharing options...
gto7419 Posted July 28, 2015 Share Posted July 28, 2015 Lol, I've had a dozen engines in 3 different cars and I've only ever seen one of those covers. They're like unicorns. Link to comment Share on other sites More sharing options...
