Canon20D Posted May 27, 2014 Share Posted May 27, 2014 So I'm trying to find out if my adjusted intake in take is leaning out my AF. I have the stock intake but I opened the holes on the front of the box. MAF is still completely stock, but it's a Perrin foam filter. After doing some 'logging' with dash command, here is a set of parameters after ~2 hr ride home. Bank A is completely nuts. Not sure if that's supposed to be that way. Any help is appreciated. http://img.tapatalk.com/d/14/05/28/qapabu7e.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RallyMachine Posted May 28, 2014 Share Posted May 28, 2014 I'm not familiar with whatever data logging method you're using... Do you have access to a vagcom or tactrix cable that you can pull a learning view? Link to comment Share on other sites More sharing options...
Canon20D Posted May 28, 2014 Author Share Posted May 28, 2014 So I exported the data from my DashCommand to a CSV file. Hopefully this will make more sense to you? Link to comment Share on other sites More sharing options...
Canon20D Posted May 28, 2014 Author Share Posted May 28, 2014 Bump Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RallyMachine Posted May 28, 2014 Share Posted May 28, 2014 I don't see a csv file. Link to comment Share on other sites More sharing options...
Canon20D Posted May 28, 2014 Author Share Posted May 28, 2014 Wtf! Grr Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Canon20D Posted May 28, 2014 Author Share Posted May 28, 2014 Ok, try this... including a CSV and a LGF from dash command. SOAB that file limit on a CSV file is annoying!!Log minus GPS.csv Link to comment Share on other sites More sharing options...
RallyMachine Posted May 28, 2014 Share Posted May 28, 2014 Formatting looks off to me. I would suggest using romraider for doing logs. Link to comment Share on other sites More sharing options...
