leggtnut Posted May 1, 2013 Share Posted May 1, 2013 So, this has been going on for about 20K or so, have to go back and look, but I have been getting surging and knocking going up one of the highways (hwy 17 from hwy 1 if you know the area). I took it in right after it started and they of course could not reproduce, figures and told me to drive it till I get a CEL, so I started getting a CEL about a month and each time I bring it by, no codes . So today, I had to get the turbo air inlet replaced (corded by blown power steering) and they gave me their scanner, and I was able to get it to pull misfires on cylinder 2,3, & 4. I returned the scanner and they weren't sure what it could be and would like it for an hour for diags now that they have a code (I think they were P0302, P0303, & P0304). The LGT has 132K on the clock and I am just hoping that this isn't going to be the start of a pattern since I am out of work and want to upgrade to a Outback or FXT shortly after I find work. Any thoughts would be great. Other than this, it has been 120K of worry free and amazing driving. Love the LGT so much. Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
leggtnut Posted May 1, 2013 Author Share Posted May 1, 2013 what. Crickets... Ben (2014 Outback SAP w/ eyesite, 2014 Tribeca Limited, 2006 LGT limited sedan) Subaru Ambassador PNW Link to comment Share on other sites More sharing options...
LatentWagen Posted May 1, 2013 Share Posted May 1, 2013 I had some surging and stuttering/hesitation going on with my '08 (especially part throttle up hill, worst when it was cold)... I replaced both O2 sensors and the problems disappeared. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Max Capacity Posted May 2, 2013 Share Posted May 2, 2013 I vote front O2 first. then rear. The front one mess's with the fuel mixture. Just read here some one said to let it sit on a cup of gas overnite to try and clean the O2 sensor. If your short on cash, I'd try that first. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
