fishbone Posted October 15, 2014 Share Posted October 15, 2014 Define "thinks". Are you saying it stays in the gear before it shifts? Does it continue to rev up while you are feeling that the car loses forward movement? You might be feeling the fact that the transmission is slipping. Link to comment Share on other sites More sharing options...
eljefe1981 Posted October 15, 2014 Share Posted October 15, 2014 Hey, can I use Mobil transmission fluid in my 05 Limited GT AT safely? And has anybody done this with no issues? I think the dealership cost is too much. Link to comment Share on other sites More sharing options...
fishbone Posted October 16, 2014 Share Posted October 16, 2014 (edited) As long as it is compatible with the Subaru ATF-HP spec, yes. Mobil 1 does not currently list that spec, although I could have sworn it used to. LE: take a look at this thread. I KNEW they changed their spec sheet because it now no longer lists JWS3309 and I know for a fact it was compatible at some point since I used it on a Mini Cooper S which called for that spec. The thread has a picture of their quart bottles from a few years ago. http://www.benzworld.org/forums/w210-e-class/1425392-new-mobil-atf-134-meets-236-a-3.html It seems ATF-HP was never on the spec list. I do believe Valvoline meets that spec, I know Amsoil does for sure, even Redline I believe. Edited October 16, 2014 by fishbone Link to comment Share on other sites More sharing options...
frank_ster Posted October 16, 2014 Share Posted October 16, 2014 i have been using mobil 1 .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
siibe Posted October 16, 2014 Share Posted October 16, 2014 Define "thinks". Are you saying it stays in the gear before it shifts? Does it continue to rev up while you are feeling that the car loses forward movement? You might be feeling the fact that the transmission is slipping. It changes off gear then theres a moment that nothing happens and revs go up and then it changes to higher gear . Is that transmission slipping ? Link to comment Share on other sites More sharing options...
frank_ster Posted October 16, 2014 Share Posted October 16, 2014 it could be the tcu needs to learn how fast to engage a specific gear. to check if its slipping use manual mode and go full throttle in each gear for a few seconds . to get the tcu to learn you need to drive around between 10-15% throttle. and you should reset the tcu before doing so if you can. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted October 16, 2014 Share Posted October 16, 2014 It changes off gear then theres a moment that nothing happens and revs go up and then it changes to higher gear . Is that transmission slipping ? Yes. But what frank_ster said is also valid, so you need to eliminate the possibility of the trans having learned to shift "lazy" by you having driven it sedate for a long time. Link to comment Share on other sites More sharing options...
frank_ster Posted October 16, 2014 Share Posted October 16, 2014 From my Understanding the tcu only learns when between 10-15% throttle . It just needs to determin how much the clutches are worn Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
eljefe1981 Posted October 17, 2014 Share Posted October 17, 2014 Thank you wishbone for the information. However, that does not answer if I can use it or not. Where can I get the other fluids that I can use with my 5EAT? Link to comment Share on other sites More sharing options...
frank_ster Posted October 17, 2014 Share Posted October 17, 2014 Any atf fluid is fine imho. I have ran pretty much what ever comes on sale. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted October 17, 2014 Share Posted October 17, 2014 Thank you wishbone for the information. However, that does not answer if I can use it or not. Where can I get the other fluids that I can use with my 5EAT? I wasn't giving you a straight answer, I was saying it is up to you and to take it for what it's worth. If the fluid you are going to use meets the specification from Subaru, being ATF-HP, then you can use it safely. I was showing you that Mobil 1 used to say it met that spec and then changed the bottle in recent years, with no seeming explanation. Where do you live? You should find Redline, Royal Purple etc at your local Walmart or any automotive store. Amsoil is only sold through local dealers and you cand find one in your area by going to amsoil.com and look up your zip code. OR (and this is your easiest option), you can call your local Valvoline oil change service center and ask them if they perform transmission fluid flushes and if they use their synthetic fluid. If they do, then take your Legacy there and have them do it. It will cost you around $100 and take about 30-45 minutes. Done and done! This is the Valvoline fluid you want http://www.valvoline.com/products/brands/valvoline/automatic-transmission-fluid/137 Link to comment Share on other sites More sharing options...
turbolgt Posted October 17, 2014 Share Posted October 17, 2014 i have had the transmission flushed on my 05 lgt 5eat for the harsh shifting from 2nd to 3rd and noticed some improvement, anyway to get rid of it all without the need to go to the dealer ? filter was replaced also Link to comment Share on other sites More sharing options...
siibe Posted October 17, 2014 Share Posted October 17, 2014 Thanks for your help frank_ster and fishbone , ill try those and see if it helps. Link to comment Share on other sites More sharing options...
haruichi808 Posted October 17, 2014 Share Posted October 17, 2014 Hi guys i forgot to ask in my last thread, but I'm going to change the transmission fluid in my 05lgt wagon it only has 29000miles now and fluid isn't really dirty but i just bought it two months ago and for my piece of mind i wanna start fresh, I heard there is a trans mesh filter in the trans and found a converted oil/trans filter behind the battery , do i change both of those when after i drain then refill ? I just want to maintain and do it the right way any info is much appreciated thank you Link to comment Share on other sites More sharing options...
frank_ster Posted October 17, 2014 Share Posted October 17, 2014 it doenst hurt to change both Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
fishbone Posted October 17, 2014 Share Posted October 17, 2014 Doesn't hurt but is excessive to change the one in the pan. Leave it alone and just do the one behind the battery, which is also excessive to do at only 29K miles on fluid that looks clean. I would leave both alone for now. Link to comment Share on other sites More sharing options...
eljefe1981 Posted October 18, 2014 Share Posted October 18, 2014 Thank you wishbone for your input, I really do appreciate it. Link to comment Share on other sites More sharing options...
haruichi808 Posted October 18, 2014 Share Posted October 18, 2014 How often am I supposed to change the filter behind the battery? Link to comment Share on other sites More sharing options...
frank_ster Posted October 18, 2014 Share Posted October 18, 2014 Technically never Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Chris GTO TT Posted October 18, 2014 Share Posted October 18, 2014 Yeah Subaru says you should only change it if it's damaged... I'm probably going to change it at about 105k on the wagon in the next few months when I flush the system. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
haruichi808 Posted October 19, 2014 Share Posted October 19, 2014 Wow ok I guess I won't change it then thx guys Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 19, 2014 Share Posted October 19, 2014 ^At your mileage don't bother. At the most flush call it good. Link to comment Share on other sites More sharing options...
sg29651 Posted October 21, 2014 Share Posted October 21, 2014 how do i know what transmission i have. 2005 legacy GT Link to comment Share on other sites More sharing options...
hadvw Posted October 21, 2014 Share Posted October 21, 2014 how do i know what transmission i have. 2005 legacy GT Well, either you have a clutch, or you don't. If you have a clutch, here we call that the "5MT" (5 speed manual transmission) - some later models have a 6MT. Otherwise, you have the "5EAT" (5 speed electronic-automatic transmission). Does that help? Link to comment Share on other sites More sharing options...
Anarcan Posted October 31, 2014 Share Posted October 31, 2014 Throwing P0761 code: shift Solenoid 'C' Performance or Stuck Off... any advice here guys before I go out and drop my pan again... already did a full fluid flush. is this something that will be repairable on the VB or is it more than likely that I will need a new OEM VB Link to comment Share on other sites More sharing options...
