Canon20D Posted April 1, 2014 Share Posted April 1, 2014 ZOMG ITS BROKE. So anyway, I noticed today that Ive got a 'dark spot' on my intercooler fins. Its too close to the turbo to not make me nervous. Anyone seen this before? Anything I should check? its got 110K on it, bone stock, and the ELM ODBII sensor I have reports that Im easily making 14psi boost so Im not sure whats up. Thoughts? Link to comment Share on other sites More sharing options...
Gex Posted April 2, 2014 Share Posted April 2, 2014 Something leak in through the hood scoop... Link to comment Share on other sites More sharing options...
FJuan Posted April 2, 2014 Share Posted April 2, 2014 Degrease it and see if it happens again. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Canon20D Posted April 2, 2014 Author Share Posted April 2, 2014 Degrease it and see if it happens again. I like this. I wiped off a little on the corner of the IC and it seemed very greasy... Link to comment Share on other sites More sharing options...
JesseH Posted April 2, 2014 Share Posted April 2, 2014 IBsoap Link to comment Share on other sites More sharing options...
FJuan Posted April 2, 2014 Share Posted April 2, 2014 Wonder if you have a crack there. Take the I/C off and plug one side up, then the other side try to plug it up with an air compressor hose in it. Try pressurizing it to 12 - 14 psi and see if you can feel any air coming out around that area. The tabs on the outside will tend to come loose, if you want to keep the I/C, clamp the tabs back into place and coat them with JB Weld. It's a temp fix. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
chato Posted April 2, 2014 Share Posted April 2, 2014 just make sure to use lots of soapy water when you clean it. Link to comment Share on other sites More sharing options...
