pheonix991 Posted December 20, 2007 Share Posted December 20, 2007 In the mornings, when it is cold, my brake light comes on, and the Ebrake isn't on. I'm wondering if the ground wire is loose. How would I fix that? Or would it be something else? I have a 97 LGT. Thanks guys. Link to comment Share on other sites More sharing options...
han Posted December 20, 2007 Share Posted December 20, 2007 Low brake fluid? Link to comment Share on other sites More sharing options...
fweasel Posted December 20, 2007 Share Posted December 20, 2007 That light is also a low fluid indicator... possible your pads have worn down enough that the fluid level in the master cylinder is very close to the low level indicator. Possible that once the car heats up a little, some air in the system expands just enough to raise the level enough to turn off the light. Or you have an electric gremlin. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
John M Posted December 20, 2007 Share Posted December 20, 2007 I'm betting low brake fluid. Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 Thanks guys. I'll check the brake fluid. Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 Alright, I checked, and it is in the middle of max and min. So, unless that is considered low, I think I'm okay there. Link to comment Share on other sites More sharing options...
fweasel Posted December 21, 2007 Share Posted December 21, 2007 Alright, I checked, and it is in the middle of max and min. So, unless that is considered low, I think I'm okay there. Eliminate the possibility, top it off to the max line. You need to be positive when ruling out options while troubleshooting, IMO. ignore him, he'll go away. Link to comment Share on other sites More sharing options...
rc0032 Posted December 21, 2007 Share Posted December 21, 2007 was it warm or cold when you checked? Hot fluid expands...check tomorrow AM Link to comment Share on other sites More sharing options...
whitetiger Posted December 21, 2007 Share Posted December 21, 2007 Eliminate the possibility, top it off to the max line. You need to be positive when ruling out options while troubleshooting, IMO. +1 Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 Eliminate the possibility, top it off to the max line. You need to be positive when ruling out options while troubleshooting, IMO. Problem with that, idk what kind of fluid is in it, and I don't want to mix different types. After reading and searching the forums more, it seems to be cold weather+driving makes it do a false reading, saying it is low when it is not. When I get some cash, I'll redo the fluid. Thanks for the help guys. rclark0032-It has been sitting outside for about 2 hours now, and it is around 50F. I'll check before I leave in the morning. Link to comment Share on other sites More sharing options...
whitetiger Posted December 21, 2007 Share Posted December 21, 2007 you can put any dot 3 brake fluid in there. 5 bucks at your local autoparts store. Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 you can put any dot 3 brake fluid in there. 5 bucks at your local autoparts store. Oh, alright, thanks!!! Link to comment Share on other sites More sharing options...
pillboy Posted December 21, 2007 Share Posted December 21, 2007 I'm betting on a sticky switch at the parking brake lever. It is still ugly. Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 I'm betting on a sticky switch at the parking brake lever. How would I go about checking this? Link to comment Share on other sites More sharing options...
pillboy Posted December 21, 2007 Share Posted December 21, 2007 You will have to take apart the console / lever boot area to get a look see at the lever mechanism (don't remember what a '97 looks like even though I drove one for 2+ years). It should be pretty obvious once you get ot the mechanism - the switch will have a wire running to it and probably a plunger that moves in and out when you move the parking brake lever. I would shoot it full of electrical contact cleaner and see if that frees things up. Have you by chance spilled sugared pop (soda) in this area? It is still ugly. Link to comment Share on other sites More sharing options...
pheonix991 Posted December 21, 2007 Author Share Posted December 21, 2007 Have you by chance spilled sugared pop (soda) in this area? Thanks, I have a copy of a service manual, so, I'll check it out after I get some brake fluid, and rule out low brake fluid. For the 4 months I've had it, I've never spilled anything down there, but, no telling what the past owners have done. Link to comment Share on other sites More sharing options...
eb50 Posted January 3, 2008 Share Posted January 3, 2008 I am having this same problem in my 05 w/ 45k. I will check the fluid tonite. Link to comment Share on other sites More sharing options...
