remico Posted June 25, 2008 Share Posted June 25, 2008 anyone know where i can pick up a pair for a good price? i saw them on ebay for 250 plus shipping but i was wondering if theyre out there cheaper..thanks question tho..i just bought a 06 spec b, would this be better for the car or worse knowing they have some special springs there Link to comment Share on other sites More sharing options...
ShadowImg Posted June 25, 2008 Share Posted June 25, 2008 Cobb sets the price the resellers can sell for, so you should get the same price from everyone -- only difference is various sellers will toss in various things for 'free' to make their value prop on it. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted June 30, 2008 Share Posted June 30, 2008 Cobb springs are good but i think JDM GT pinks on your car is a better choice. The cobbs are great though on the GT which i run,i think they might be intended for the spec b to. Link to comment Share on other sites More sharing options...
remico Posted June 30, 2008 Author Share Posted June 30, 2008 what makes the pinks better? i know the spec b has different suspension so you think they will work better then the cobb? Cobb springs are good but i think JDM GT pinks on your car is a better choice. The cobbs are great though on the GT which i run,i think they might be intended for the spec b to. Link to comment Share on other sites More sharing options...
sactojesse Posted June 30, 2008 Share Posted June 30, 2008 what makes the pinks better? i know the spec b has different suspension so you think they will work better then the cobb? I believe Cobbs are designed to fit the stock USDM LGT's KYB front struts, whereas pinks are designed to fit the Spec B and JDM LGT's Bilstein front struts. Link to comment Share on other sites More sharing options...
HansGT Posted June 30, 2008 Share Posted June 30, 2008 ^ you got it. I think Cobb are for the KYB's only. But give them a call they may have Spec B specific length springs. STI Pinks are true JDM for Subaru. They spring rate are about 10% greater than stock and drop the car an inch...a nice mild improvement. Swift are a bit more aggressive with about a 4-5mm more drop in the front. Other springs available...Wangan, Tein, etc. Read these... http://legacygt.com/forums/showthread.php?t=61108 http://subiwiki.com/wiki/index.php/BL_%282005-2009%29#Handling_Modifications http://www.legacygt.com/forums/showthread.php?t=67940 Link to comment Share on other sites More sharing options...
