rbuck Posted January 7, 2007 Share Posted January 7, 2007 I purchased a 2007 Legacy Spec.B last month and have been generally happy with the vehicle. However, I have noticed a fairly strong vibration in the gearbox that manifests itself through the shift lever (particularly in 4th gear between 2-3,000 RPM) and also shows up as an audible chattering that seems to be present in all higher gears in the same engine speed range. The final symptom is a strong audible gearshift vibration under heavy acceleration in all gears. Dealer says it's normal but it really detracts from the overall performance and feeling of quality. Has anyone else with a Spec.B 6 speed (or Legacy 5 speed) seen this symptom? Link to comment Share on other sites More sharing options...
G.T.Subie Posted January 7, 2007 Share Posted January 7, 2007 I don't have any answer but that doesn't seem normal:confused: Denial is your best friend Link to comment Share on other sites More sharing options...
bmorrisj Posted January 7, 2007 Share Posted January 7, 2007 my shifter makes noise but it looks like one of the linkages under the car had a loose fitting bushing... i noticed this when the tranny came out.... Link to comment Share on other sites More sharing options...
DukeTrout Posted January 8, 2007 Share Posted January 8, 2007 That does not sound normal at all. Ditto bmorrisj on the bushing question. Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
edkwon Posted January 8, 2007 Share Posted January 8, 2007 nope, i dont have a problem like that at all in my spec B Ed Link to comment Share on other sites More sharing options...
VXCL Posted January 8, 2007 Share Posted January 8, 2007 the problems is your 18s. sell them to me and find some used 17s hahahaahahah MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
JABBER Posted January 8, 2007 Share Posted January 8, 2007 no problems with my 07 spec B. Link to comment Share on other sites More sharing options...
badfish11 Posted January 8, 2007 Share Posted January 8, 2007 I have an 06 spec b, the shifter vibrates more than I've exerienced in othe cars but I really didn't think there was anything broken. I have no audible chatter though. Link to comment Share on other sites More sharing options...
hogmeat Posted January 8, 2007 Share Posted January 8, 2007 My 06 GT is fine in all gears except 3rd. If you shift and take your hand off the shifter, it's perfect - no noise, no vibration. If you put ANY downward pressure towards neutral - it will vibrate. No noise though. My gearbox is otherwise fine, no shifting issues, no noises, no popping out of gear. I don't even worry about it, cause your not supposed to have hands on shifter if your neat shiting anyways. I'm pleasantly surprised... It was most certainly worth the couple bucks and 10 mins of my time. CLICK HERE FOR THE HOGZAUST Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted January 8, 2007 Share Posted January 8, 2007 My '86 Celica, my GF's 2001 Saturn, and my Prelude all have manual shifters that do not vibrate at all. So when I test drove the 05 LGT I found that it vibrated - it was the first thing I noticed and I didn't like it at all. Later on I heard from others that it's "better" that it vibrates because you have a direct connection to the transmission. Personally I don't know how it's "better" save for less parts to break and maybe takes 6 - 15 lbs off the curb weight... Is yours vibrating more than it did when you first got it or has it always done it that bad? Link to comment Share on other sites More sharing options...
Pip Posted January 9, 2007 Share Posted January 9, 2007 No such vibration on mine (1500 miles on vehicle). Link to comment Share on other sites More sharing options...
mand3j Posted January 9, 2007 Share Posted January 9, 2007 nothing in mine either. 3000miles Link to comment Share on other sites More sharing options...
rallysquirrel Posted January 9, 2007 Share Posted January 9, 2007 nothing in mine 5600 miles. Link to comment Share on other sites More sharing options...
GTTuner Posted January 9, 2007 Share Posted January 9, 2007 Subaru's in general do give some engine vibration through the MT shifter. However, the chatter noise may be the throw- out bearing. Drive in the range where you hear the audible chattering and lightly put pressure on the clutch pedal to see if the noise disappears or changes. The TO bearing is some type of "self centering"??? unit. Mine did the exact same thing when I got my car back from the clutch install. It went away after a thousand miles and has not returned. Link to comment Share on other sites More sharing options...
edkwon Posted January 9, 2007 Share Posted January 9, 2007 Guys with the 5 speeds (regular GT and 06 specBs) i think the OP had questions about noise concerning the 6MT specifically, not the 5MT. Ed Link to comment Share on other sites More sharing options...
GTTuner Posted January 9, 2007 Share Posted January 9, 2007 Dealer says it's normal but it really detracts from the overall performance and feeling of quality. Has anyone else with a Spec.B 6 speed (or Legacy 5 speed) seen this symptom? From his first post. Link to comment Share on other sites More sharing options...
GTTuner Posted January 15, 2007 Share Posted January 15, 2007 Any luck with your problem? Update please! Link to comment Share on other sites More sharing options...
NutBucket Posted January 15, 2007 Share Posted January 15, 2007 My '86 Celica, my GF's 2001 Saturn, and my Prelude all have manual shifters that do not vibrate at all. So when I test drove the 05 LGT I found that it vibrated - it was the first thing I noticed and I didn't like it at all. Later on I heard from others that it's "better" that it vibrates because you have a direct connection to the transmission. Personally I don't know how it's "better" save for less parts to break and maybe takes 6 - 15 lbs off the curb weight... Is yours vibrating more than it did when you first got it or has it always done it that bad? You said it, direct linkage on Subaru/RWD cars vs. the cable setups (most common anyway) on the other cars you mentioned. Link to comment Share on other sites More sharing options...
Legacy18E Posted January 15, 2007 Share Posted January 15, 2007 I had a 05 GT at 35k with no shifter problems and now I have a 07 spec b at 1k miles with no such problem Link to comment Share on other sites More sharing options...
Gator GT Posted March 31, 2007 Share Posted March 31, 2007 re-birth.... haven't felt any vibrations as the OP has stated. I'm getting more of a hit or miss notchy feeling (like catching the synchros) through the gate and then an unsettling meshing noise upon decceleration esp. in 1st and 2nd. "If we are to guard against ignorance and remain free, it is the responsibility of every American to be informed." - T. Jefferson Link to comment Share on other sites More sharing options...
EuLoGy Posted August 1, 2007 Share Posted August 1, 2007 I have a new 08 Spec.B and it seems to have some chatter. It is hard to diagnose because it doesnt happen all of the time. It happens in lower gears and especially when I decel. It has happened while cruising slowly over abrupt bumps in the road such as railroad tracks. Link to comment Share on other sites More sharing options...
Crawdaddy79 Posted August 1, 2007 Share Posted August 1, 2007 my GF's 2001 Saturn, and my Prelude She's my wife now, and her brother has her Saturn while she now drives the Prelude. Oh my how times have changed. Link to comment Share on other sites More sharing options...
SpecBee Posted August 2, 2007 Share Posted August 2, 2007 I think it is the standard subie tanny feel. I've had to foresters and now a specB. They all felt similar "a little grainy" coming from previous Acuras with silky smooth trannys. I never thought anything was wrong and I attributed this grain feel to the "transfer case feel" more wheel/gears in motion. I will say that the 6mt does feel smoother than the last 2-5mts in the foresters. If you leave your hand on the shifter while driving you can definitely feel the grain. If this is your first subie then you may not be used to the feel. Anyway just my opinion. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted January 24, 2008 Share Posted January 24, 2008 wanna trade Link to comment Share on other sites More sharing options...
pathfin9 Posted January 24, 2008 Share Posted January 24, 2008 I've posted about the chatter and vibration before. I had it also in 1st-3rd in low rpm range, usually heard it the most on decel. I've got an 08 Spec B. I took it to the dealer, and they def. heard and felt the noise. However, another member on here called up for the same issue. So in turn, the dealer, said they would call Subaru. Subaru told them, they havent had any issues with the transmissions, and to check it with another Spec B they had on the lot. They did this, and were able to repeat it on that car as well. So, apparently its normal. I was still skeptical about this, but I recently test drove a 2008 STi for work and it had the same noise and feel. Although, I must say, the newly revised 6-speed in it felt a lot better than what is in the 2008 Spec B. Its tighter and more crisp. So I hope that helps put your mind to ease. I'm pretty sure its normal. I havent seen, felt, or heard anything otherwise that tells me that its something bad, and I've put almost 8,000 miles on her since Sept. -John Link to comment Share on other sites More sharing options...
