jhawk222 Posted March 25, 2012 Share Posted March 25, 2012 Finally got around to changing my front collars today. As I was tightening the nut the stud broke off. I was thinking of drilling through the stud and possibly welding a nut on the backside so I can use the same type of screw on the other end of the collar?! Any and all ideas are greatly appreciated. Link to comment Share on other sites More sharing options...
captainobvious Posted March 25, 2012 Share Posted March 25, 2012 I would recommend drilling it out and retapping the hole so you can resuse you rbolt again. Welding IMO isnt the best option Link to comment Share on other sites More sharing options...
jhawk222 Posted March 25, 2012 Author Share Posted March 25, 2012 ^^Drilling it out would not allow me to reuse the bolt. The way the collar is configured allows for a screw to fasten forward facing mounting point and a nut on the rearward facing mounting point. Once I drill out the screw it forces me to tap for a larger screw or weld the nut on the backside. Decisions, decisions! Link to comment Share on other sites More sharing options...
jhawk222 Posted March 26, 2012 Author Share Posted March 26, 2012 Drilled out the broken stud. Will continue in the morning and post results. Link to comment Share on other sites More sharing options...
jhawk222 Posted March 26, 2012 Author Share Posted March 26, 2012 Figured I'd change the ball joints while I'm at it. Boy are they rusted in place....nt even the PB is freeing them. And I just changed my passenger side front axle a couple of months back!!! Link to comment Share on other sites More sharing options...
jhawk222 Posted March 27, 2012 Author Share Posted March 27, 2012 Actually had a pleasant trip to the stealership! Got a like threaded bolt slightly longer for the swaybar collar. All back together and ready to go!!! Link to comment Share on other sites More sharing options...
