93EJ Posted July 30, 2009 Share Posted July 30, 2009 Hey guys, I just purchased a fairly new Garrett T25 turbo for my 93ej i was wondering what kind of manifold i should use, Wrx, Sti, Etc. Thanks Spb Link to comment Share on other sites More sharing options...
987687 Posted July 30, 2009 Share Posted July 30, 2009 93ej? There isn't any subaru engine with that name. do you mean a 1993 ej engine? Link to comment Share on other sites More sharing options...
byronchrisp05 Posted July 31, 2009 Share Posted July 31, 2009 The t25 is a straight t2 flange so you will need some kind of adptor plate to bolt up to stock up pipe. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 31, 2009 Share Posted July 31, 2009 first the OP needs to figure out what kind of car he has with what engine and what turbo setup. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Platinum_Racing Posted August 1, 2009 Share Posted August 1, 2009 It has to be an EJ22. If it's an EJ22 N/A, or an EJ22T we'll have to find out. Either way the STI/WRX manifolds are pretty much the same (If not identical). I'm all but certain neither one will fit on the EJ22. If you want to do something to the intake manifold, take the stock one off along with the heads and port them (Or have them ported) to get better airflow. Don't forget to port match the gaskets or the airflow will be so turbulent you'll actually reduce power instead of increasing it. Next bottleneck... Stock exhaust pipes/stock cat...... Link to comment Share on other sites More sharing options...
legacy gt2.5 Posted March 19, 2014 Share Posted March 19, 2014 Will a t25 fit on. 05 legacy Link to comment Share on other sites More sharing options...
mwiener2 Posted March 24, 2014 Share Posted March 24, 2014 T25 is a flange size, not a turbo. And a T25 flange will not fit any subaru without modification... like a rotated turbo setup My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
covertrussian Posted March 30, 2014 Share Posted March 30, 2014 Actually T25 is a turbo, Nissan used it on most turbo SR20DET's blocks. Fun little turbos on 2.0L motor, quick spool but tops out at 250whp on pump gas. T2 is the flange size that all Garrett T25, T28, GT25, GT28 use. When you go Garret GT30 it's a T3 flange, finally GT40 is T4. Easy way to tell which flange to use. This is what a T2 flange looks like: http://images.rvsmods.com/var/albums/Cars/G20tKH3/Mods/Turbo/Turbo/GTiR-T28/CIMG7271.JPG?m=1334037642 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
mwiener2 Posted April 2, 2014 Share Posted April 2, 2014 No. Edit: So now that I got my "No" in, let me explain why you think you know what you are talking about because you spend too much time on forums..... The "Ebay" community likes to use "T25/T28" as a turbo size.... It's not, it's a flange size. You can have turbos that make 100hp all the way up to 600+hp in a T25 flange. That could be 30 different turbos with the same T25 size flange. They are only all T25 turbos because they share the same flange size, which has very little to do with the actual size of the turbo. This website is a perfect example. http://www.cxracing.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=T25T28 12 different turbos all under the T25/28 listing. Some of those turbos are listed as a GT28... which is an actual Garret size of turbo. But again, there are about 6 different size turbos in the Garrett GT28 line that range from 200hp to 600hp. This is left over from early turbo cars in the 80's and early 90's where there were only a handful of turbos floating around and the size of the flange dictated the power more than anything. So please help the community prosper and learn the proper nomenclature of the parts you talk about every day. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
covertrussian Posted April 9, 2014 Share Posted April 9, 2014 Garrett Nomenclature: http://www.turbobygarrett.com/turbobygarrett/garrett_nomenclature In the Nissan community (where Nissan used Garrett turbos stock), we refer to the flange as the T2 flange. Under T2 flange you have the following turbos: T25, T28, GT25xx, GT28xx etc. Now there is a DSM T25 which does not use a T2 flange (once again T25 is turbo, T2 is flange). Note that Garrett long discontinued the regular T25 and T28's (journaled bearing), they now mainly sell the GT series (which are mostly ball bearing). This is why you wont really find "T25" or "T28" turbo names, instead you will see "GT25" or "GT28", but these still use the T2 flange. Here is a Garrett T25 that came stock on a Nissan Avenir W10: http://images.rvsmods.com/var/albums/Cars/B15/Turbo/Turbo/T25/CIMG8906.JPG?m=1346045073 http://images.rvsmods.com/var/albums/Cars/B15/Turbo/Turbo/T25/CIMG8887.JPG?m=1346045070 Here is a Garrett T28 that came stock on a Nissan Sunny GTiR. You can buy one new from Nissan here (notice the name): http://gspec.com/p-7251-gti-r-t28-turbo.aspx http://images.rvsmods.com/var/albums/Cars/G20tKH3/Mods/Turbo/Turbo/GTiR-T28/CIMG7285.JPG?m=1334037670 You probably wont believe me still, at this point you can remain naive about Garrett naming nomenclature, but don't miss-educate others. Don't accuse me of just "browsing forums", I've built a few Nissan SR20's with a wide verity of turbos, from T25 to T3's. Here are two pics of T2 vs T3 styled turbos on the same car (GT2860r "Disco Potato" in this picture) http://images.rvsmods.com/var/albums/Cars/G20tKH3/Mods/Turbo/IC-Piping/SAM_4713.JPG?m=1364846674 (Precision T3 in this pic) http://images.rvsmods.com/var/albums/Cars/G20tKH3/Mods/Turbo/IC-Piping/CIMG9868.JPG?m=1310495196 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
mwiener2 Posted April 11, 2014 Share Posted April 11, 2014 Point is you still have no idea what turbo or flange the OP is talking about My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Nubie Posted April 11, 2014 Share Posted April 11, 2014 Just to fuel the fire, Undercoverussian is right... A full T series existed before the GT series of turbos. But Mike is right also... We still dont know about the OP's setup in question. Link to comment Share on other sites More sharing options...
FJuan Posted April 11, 2014 Share Posted April 11, 2014 Why are you guys debating on a 2009 thread? I'm sure the OP have moved on with his life. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
covertrussian Posted April 11, 2014 Share Posted April 11, 2014 Haha just noticed the date, eh information is information. Point is you still have no idea what turbo or flange the OP is talking about That is true, I am used to seeing a specific turbo when someone says T25 (the Nissan used stock), it almost doesn't seem like they really went past T25 nomenclature before GT series turbos. T25 would mean a certain compressor + turbine wheels, but with the GT series they would specify the compressor and turbine wheels as part of the name aka GT2556r. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
mwiener2 Posted April 14, 2014 Share Posted April 14, 2014 A GT series turbo is sold without the turbine housing.... because there are some many options for each size. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
covertrussian Posted April 15, 2014 Share Posted April 15, 2014 A GT series turbo is sold without the turbine housing.... because there are some many options for each size. Depends on where you get it from and weather or not it's an OEM replacement turbo. Most common for GT2x turbos is .60 AR T2 flange. Going T3 flange is pointless for most GT25/GT28 turbos since it requires a much bigger manifold. Usually people will get GT3x turbo, which comes with T3 flange by default, and get a T2 flange to fit the stock Nissan T2 manifolds since stock manifolds are dirt cheap ($100). 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Nubie Posted April 15, 2014 Share Posted April 15, 2014 GT3x does not come with T3 as default, it comes with no housing. Technically you are buying two part numbers, one being the turbo and another being the housing. With that being said yes some vendors package them together as you cant use one with out the other. Link to comment Share on other sites More sharing options...
mwiener2 Posted April 16, 2014 Share Posted April 16, 2014 covertrussian, you are about 15 years behind on turbo tech My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
covertrussian Posted April 16, 2014 Share Posted April 16, 2014 covertrussian, you are about 15 years behind on turbo tech More like 20 years behind, I've been building SR20's for last 5 years. They are over 20 years old now. That's why I questioned you when you said T25 is a flange size and not turbo. T25 is the most common turbo that shipped with Nissan SR20's. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
mwiener2 Posted April 17, 2014 Share Posted April 17, 2014 Welcome to the rest of the automotive world where T25 is a flange, not a turbo. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Nubie Posted April 17, 2014 Share Posted April 17, 2014 Nissan used a T25 turbo, Saab used a T25 turbo, Mitsubishi used a T25 turbo, Land Rover used a T25 turbo... Link to comment Share on other sites More sharing options...
mwiener2 Posted April 21, 2014 Share Posted April 21, 2014 In 1990. You cannot just go and order a "T25" turbo and expect to get a direct fit for your existing "T25" turbo. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
