jproy12 Posted April 14, 2010 Share Posted April 14, 2010 Hey guys, I didnt really search, but how do you adjust the rear camber on the legacy with stock struts and lets say tein h-techs? I dont want uneven wear, so i know the front can be adjusted, but how do you adjust the rear camber? What do i need? JP Link to comment Share on other sites More sharing options...
N.sane Posted April 14, 2010 Share Posted April 14, 2010 You need aftermarket rear lateral links. I believe Perrin is the only available option right now. 4boxparts made nice ones but no longer makes them as far as I know... Link to comment Share on other sites More sharing options...
Th3Franz Posted April 14, 2010 Share Posted April 14, 2010 adjustable links. It's not as bad as the front, though. The main thing is to adjust the toe when you lower the car, which can be done with the stock hardware in the rear. FWIW, I haven't touched the camber settings in the rear, only the toe and my tire wear is fine. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
FPerron Posted April 14, 2010 Share Posted April 14, 2010 Sure, but if you're tracking the car, you're leaving traction on the table unless you increase front and rear negative camber. I'm running -2.5 front, -1.8 rear. In fact, most DOT track tires recommend even more negative camber than this. Link to comment Share on other sites More sharing options...
CDN 2.5i Posted April 14, 2010 Share Posted April 14, 2010 hey JP - should have bought the Perrin lateral links I was selling... Perry picked them up. I'm going to run the 4BoxParts version in a month or so before I do my summer alignment. As Franz states - your rear tire wear shouldn't be bad with just H-Techs. The increased camber you get with lowering is not that significant. Link to comment Share on other sites More sharing options...
Drew888 Posted April 18, 2010 Share Posted April 18, 2010 With my car I have discovered that -2.0f and up to -1.5 rear give perfectly even wear. Now I'm also at -2.5f / -1.8r and have noticed more inner wear on the front but apparently the rear seems, at a quick glance, to still be wearing evenly. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 18, 2010 Share Posted April 18, 2010 Whiteline part number KCA399. Done. No need for lateral links. I swear, some times I worry about some of you guys! And, in general, toe wears tires. Not camber. Plenty of locals run -3* with zero toe and get PLENTY of life out of tires. Toe wears tires orders-of-magnitude faster than camber will. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
wpgspecb Posted April 20, 2010 Share Posted April 20, 2010 so you cant adjust camber in rear in stock form at all ? Link to comment Share on other sites More sharing options...
jproy12 Posted April 20, 2010 Author Share Posted April 20, 2010 so you cant adjust camber in rear in stock form at all ? Nope, you need aftermarket lateral links! Or those bushings... JP Link to comment Share on other sites More sharing options...
wpgspecb Posted April 21, 2010 Share Posted April 21, 2010 Daauuummmmmm Link to comment Share on other sites More sharing options...
jproy12 Posted October 19, 2010 Author Share Posted October 19, 2010 Bumping my old tread, got some Epic Springs in the mail! Has anyone found a way to adjust the rear camber? Is it even necessary with a 1" drop at the most? JP Link to comment Share on other sites More sharing options...
Th3Franz Posted October 19, 2010 Share Posted October 19, 2010 I haven't found a need to yet on street tires. I push the car more than 99% of people on this board. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 19, 2010 Share Posted October 19, 2010 Whiteline part number KCA399 [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jproy12 Posted October 19, 2010 Author Share Posted October 19, 2010 ^^ that part number seems to only apply to 04 and older models, not my 06 lgt! So I don't really need any camber kit for this drop? JP Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 19, 2010 Share Posted October 19, 2010 I have it on my 09 OBXT... [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jproy12 Posted October 19, 2010 Author Share Posted October 19, 2010 Well then! Should work on my car then! Is it necessary tho? JP Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 19, 2010 Share Posted October 19, 2010 Do you want to be able to adjust camber at all in the rear? Then it's necessary. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
jproy12 Posted October 19, 2010 Author Share Posted October 19, 2010 That's my question actually, is it really needed? If I don't use these, I assume ill have negative camber in the rear? Do I need it, that's the question! I'm most likely upgrading to swaybars, so might be worth it! JP Link to comment Share on other sites More sharing options...
Th3Franz Posted October 19, 2010 Share Posted October 19, 2010 You end up with slightly more than -1 degrees of camber in the rear depending on your drop. It's not enough to affect tire wear if that's your concern. You don't really need much more than that for street tires because of the multi-link design. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
wpmarky Posted October 19, 2010 Share Posted October 19, 2010 WL KA399- applicable models: Subaru Legacy BL,BP 09/03-08 all Subaru Outback BP 03-08 wagon inc XT turbo http://www.whiteline.com.au/product_detail.php?part_number=KCA399&page=2 You can get -1ish camber on front and rear with stock bolts. I you want more, you'll need the bushings for the rears, or camber bolts/plates for the front. I ran -1.1 front and rear for my first couple track days, will be increasing that shortly when the new coilovers come in. For DD/spirited driving, -1 is good enough. Link to comment Share on other sites More sharing options...
jproy12 Posted October 20, 2010 Author Share Posted October 20, 2010 ^^ that's the answer I wanted! So no need to get anything else? Just swap the springs and get it alligned after? Thanks for the links and info. JP Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 20, 2010 Share Posted October 20, 2010 Be aware, there is absolutely zero rear camber adjustment. What you get, is what you get. If you drop it, and you have -1.3º, then that's what you get. The KCA399 is an easy install, and relatively innexpensive. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
sheppo9 Posted October 20, 2010 Share Posted October 20, 2010 There is camber bolts in the back from the factory. They go in the rear crossmember, and the bent/banana shaped arm attaches to them. #2 in this picture; http://opposedforces.com/parts/legacy/us_b13/type_17/suspension_and_axle/rear_suspension/illustration_2/ Yes the adjustment range is crap, but they are still there. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 20, 2010 Share Posted October 20, 2010 Isn't #2 in that picture the toe-adjustment cam? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
sheppo9 Posted October 21, 2010 Share Posted October 21, 2010 No, #2 is for camber, as I said thou, there is only a little bit of adjustment in them. If you want to adjust Toe, you need camber bolts (if they even fit?) in the smaller, front arm - or those Whiteline KTA124 (which I'm posting a new thread about 1 breaking...). Link to comment Share on other sites More sharing options...
