Kevin03045 Posted February 9, 2010 Share Posted February 9, 2010 After doing extensive searching I have come to the conclusion that the CEL you can get from removing the UP EGT probe is eliminated with a Cobb AP Ver2. And I don’t have to do the 2.2 KOhm 1/2 watt resistors in the harness plug where the probe goes. Is this a correct statement??? Link to comment Share on other sites More sharing options...
rao Posted February 9, 2010 Share Posted February 9, 2010 That is correct. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 9, 2010 Share Posted February 9, 2010 No idea. If you can afford to spend on a AP2 you can afford $1.99 for a resistor fix which literally takes 10 seconds including snipping down the resistor and opening the hood. PM me if you need pics. Link to comment Share on other sites More sharing options...
Kevin03045 Posted February 9, 2010 Author Share Posted February 9, 2010 No idea. If you can afford to spend on a AP2 you can afford $1.99 for a resistor fix which literally takes 10 seconds including snipping down the resistor and opening the hood. PM me if you need pics. I understand but why do something if you don’t have to... Work smarter not harder... Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 9, 2010 Share Posted February 9, 2010 I understand but why do something if you don’t have to... Work smarter not harder... In that case just leave your EGT hanging in the engine bay. Link to comment Share on other sites More sharing options...
Kevin03045 Posted February 9, 2010 Author Share Posted February 9, 2010 In that case just leave your EGT hanging in the engine bay. Good point. Will it harm anything if I do both??? & how do I make sure it’s sealed from moisture issues. Link to comment Share on other sites More sharing options...
m sprank Posted February 9, 2010 Share Posted February 9, 2010 Should not hurt anything. I have seen them zip tied in the engine bay. But, some members save them and some sell them. Many break them trying to remove. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 9, 2010 Share Posted February 9, 2010 Should not hurt anything. I have seen them zip tied in the engine bay. ^ what he said. I was being funny when I said let it hang out in the engine bay, but was also serious. The reason I did the 2.2k .5w resist mod was to get the opensource going quick. We were able to remove my sensor undamaged so I just unplugged it. It has 2 tips so it is obvious where to put each end of the resistor. I figured the resistor would not give me issues later and I could put the sensor back in and go to stock easy enough. The resistor is really easy to do. It looks like this: ----------<XXX>---------- With anything handy (snips, wirecutters, scissors) cut the long wire leads to look like this: -----<XXX>----- Bend it into a U and insert it where the sensor previously was in your harness. Stage 2 resistor mod option: cover with electrical tape to keep dry. EDIT: The resistors come in packs of 5. If you have no "shack" local I will send you a few! I have 4 extra! Link to comment Share on other sites More sharing options...
gotsflat4love Posted February 11, 2010 Share Posted February 11, 2010 I have been looking for months now how to install the resistor. Can someone provide me with pics of this. I have searched this and can't find. Everyone and there mother say how easy it is, but I am a visual learner. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
m sprank Posted February 12, 2010 Share Posted February 12, 2010 Trace the line from the sensor up to right next to the passenger side top hat. There is a bracket holding the plug connectors for the EGT and front O2. Disconnect the EGT connector. In the end that goes back into the harness (not the end going to the EGT sensor) shove the resistor in. One end into each of the two terminals. Shorting the two together through the resistor. Wrap it up with electrical tape to keep it in and dry. Sorry, no sensor on my two 08's or I would snap a pic for you. Link to comment Share on other sites More sharing options...
