Dispatch20 Posted August 29, 2014 Share Posted August 29, 2014 So I bought Mr.Hicksta's badass car a couple weeks back and there was one minor issue with his amazing stereo system. The Alpine subwoofer fader knob didn't work. The broken knob made it so you'd have to use the equalizer in the double din head unit to adjust subwoofer bass, which is annoying while driving. Sometimes you want a lot of bass to rattle your teeth fillings, and sometimes you don't. I had to fix it! First, here's a few pictures of mr.hicksta's impressive build: http://i82.photobucket.com/albums/j253/Dispatch20/DSC01116.jpg http://i82.photobucket.com/albums/j253/Dispatch20/DSC01117.jpg This plate is just genius, and seems to fit perfectly there: http://i82.photobucket.com/albums/j253/Dispatch20/DSC01118.jpg So here is the RUX-Knob cleanly installed in the armrest console area: http://i82.photobucket.com/albums/j253/Dispatch20/DSC01111.jpg The knob uses a telephone cord to run back to the Alpine subwoofers to control their gain. The single telephone cord leaving the knob enters a phone splitter and enters the amps (white cords): http://i82.photobucket.com/albums/j253/Dispatch20/DSC01115.jpg So like I mentioned, there was an issue with the setup, and the knob didn't work. I dug around for a bit and here is what I learned: The telephone cable (RJ14) provided in the RUX-knob kit uses a straight-through design, which is unlike a typical RJ14 telephone cable: http://i82.photobucket.com/albums/j253/Dispatch20/DSC01110.jpg If this was a standard telephone cord, the colors would be reversed across the pair. Therefore, if you want to hook up two amps to the fader knob, you have to be very careful what type of cable you use. If you use a splitter and two telephone cords that hook into phones, you will end up with a reversed pinout. This is exactly what happened during the stereo install. I fixed this reversed pinout by adding a phone coupler like the one here: http://www.radioshack.com/product/index.jsp?productId=4394903 The nice worker at Radio Shack gave me a multimeter to verify that the phone couple inserted a crossover/rollover. I added the coupler and jammed all the cables back into wherever they would fit under the seats and behind the side bolsters: http://i82.photobucket.com/albums/j253/Dispatch20/DSC01119.jpg And voila! The fader knob now works and I can quickly adjust the subwoofer gain without hitting all sorts of equalizer buttons. Next thing to fix? I can see daylight out of the lower rear trunk. The sound insulation is pushing the trunklid out a little bit. It doesn't seem to cause any water to get in the trunk, though. http://i82.photobucket.com/albums/j253/Dispatch20/10858d94-0415-4fbf-adb1-1edbae412572.jpg Link to comment Share on other sites More sharing options...
