Noise from steering wheel area
So my steering wheel is squealing when turning left and right. Sounds like rubber boots when you squeeze on them.
It's coming from right behind the steering wheel and the column(the gap there)
Easy fix or expensive repair?
Had whole new rack and pinion put one a couple of months ago, PS fluid is at the minimum but its making noise right behind the steering wheel
Sprayed wd40 in the gap but no luck
