M4rked1 Posted June 30, 2016 Share Posted June 30, 2016 So I picked up a 2005 Legacy GT that doesn't run right for a song, and now my plan is to return her to her former glory! I have searched the forums quite a bit and have formulated some semblance of a plan. I thought I would also track my progress on here, for fun, and hopefully get some suggestions along the way. So in summary the problems are: Car does not idle well, sometimes stalls out, throwing a cyl 2 misfire CEL. This is by far the most pressing issue and likely the focus of all my efforts. Based on a few nights of research I have decided the potential failures are: Intake manifold gaskets Injector Bent Valve Burnt Valve Damaged piston/cyliner AVCS solenoid Much less important, I am also going to tackle: exhaust leak, Popped seam on drivers seat, moonroof stuck on one side, grille broken. Picture of the beaut: http://i.imgur.com/bZstdYS.jpg Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 30, 2016 Share Posted June 30, 2016 Hopefully is the IM gaskets but if its any of the other causes be prepared to spend several thousands to restore the car. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2016 Share Posted June 30, 2016 Welcome tot he Forum, you've come to the right place. Read the sticky's at the tops of the forum's, especially the 4th Gen forum. http://people.csail.mit.edu/ilh/vacation/ The 05 GT's start around page 1604, look in the back around page 5600 for how things work. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted June 30, 2016 Author Share Posted June 30, 2016 Max Capacity, that manual is fantastic! Thank you for posting that, I am sure it will be invaluable. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2016 Share Posted June 30, 2016 Your welcome. Your also close to the best Tuner for these cars. He uses the dyno at ESP in Sterling MA. contact http://www.tuningalliance.com for parts and tuning. Trust me, you'll never want to sell the car. Mike has kept my wagon happy and a joy to drive for many years now. email him from his site he can get most any part you need. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 1, 2016 Author Share Posted July 1, 2016 Finally was able to put the car in the garage, couldn't drive on the concrete until today due to the floor being freshly poured. (Long story) Waiting on a few more parts and tools before I start, but this is where she will live for a while! http://i.imgur.com/EKYKJry.jpg Link to comment Share on other sites More sharing options...
M4rked1 Posted July 4, 2016 Author Share Posted July 4, 2016 Finally got to work on the car, so the first thing was a compression test. Upon removing the plugs I noticed cyl 2 smelled strongly of gas. Compression test was done with jumper cables to a battery on the floor, so the crank was a tiny bit weak. And the engine was cold. Results are: Cyl 2 45psi Cyl 4 90psi Cyl 1 95psi Cyl 3 90psi So gas smell with low compression say valve problem to me. I guess the engine comes out this week. Link to comment Share on other sites More sharing options...
whitrzac Posted July 4, 2016 Share Posted July 4, 2016 More likely a cracked piston Link to comment Share on other sites More sharing options...
M4rked1 Posted July 5, 2016 Author Share Posted July 5, 2016 More likely a cracked piston Why do you say that? Link to comment Share on other sites More sharing options...
CTGT Posted July 5, 2016 Share Posted July 5, 2016 Subscribed. Can't wait to see the results. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 5, 2016 Author Share Posted July 5, 2016 Just about ready to pull the engine. Question, keep the exhaust manifold on? Or remove? http://i.imgur.com/s0yQvID.jpg Link to comment Share on other sites More sharing options...
FJuan Posted July 5, 2016 Share Posted July 5, 2016 Why do you say that? A cracked piston or worn out piston rings is more common with this model year than burnt valves. You don't have to take off the exhaust manifold when pulling the motor. You should pull the front O2 sensor off before pulling the motor to prevent damage to it. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2016 Share Posted July 5, 2016 Read my click here link... Leave the manifolds on until the engine is on the stand. Take the fuel lines off at the shock tower. Leave the motor mounts on the engine too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
M4rked1 Posted July 6, 2016 Author Share Posted July 6, 2016 Engine is out, thank you all for the advice! http://i.imgur.com/ZC5XyfL.jpg Link to comment Share on other sites More sharing options...
FJuan Posted July 6, 2016 Share Posted July 6, 2016 Good luck with the tear down. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 6, 2016 Author Share Posted July 6, 2016 Neat little trick I found on YouTube to hold everything while you remove the crank and cam bolts http://i.imgur.com/LQCe4G9.jpg So is my intake cam of off a tooth? Things aren't lining up perfect http://i.imgur.com/SnBSexD.jpg http://i.imgur.com/xGk0MMN.jpg http://i.imgur.com/K41yZgp.jpg http://i.imgur.com/JeCQerl.jpg Link to comment Share on other sites More sharing options...
M4rked1 Posted July 6, 2016 Author Share Posted July 6, 2016 It's an exhaust valve That video was taken with the cams out, with the cam installed there was zero clearance between the bucket and the lobe. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 6, 2016 Share Posted July 6, 2016 The fact you have the space and facilities and savvy to do the work is light years ahead of most of these threads Typically it's "I got a sweet deal.....not sure why it knocks" lineage. Did you do a leak down test? I guess at this point it doesnt matter given the psi reading. Seem like you wont have an issue with the project I aspire to your level of garage-dom Link to comment Share on other sites More sharing options...
FJuan Posted July 6, 2016 Share Posted July 6, 2016 It's an exhaust valve That video was taken with the cams out, with the cam installed there was zero clearance between the bucket and the lobe. I retract my earlier statement, you are one of the few with a bad valve seat. Did you inspect the cylinders and pistons for wear or cracked ringlands? How do they look? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 6, 2016 Author Share Posted July 6, 2016 The fact you have the space and facilities and savvy to do the work is light years ahead of most of these threads Typically it's "I got a sweet deal.....not sure why it knocks" lineage. Did you do a leak down test? I guess at this point it doesnt matter given the psi reading. Seem like you wont have an issue with the project I aspire to your level of garage-dom Wow, high praise, thanks! Google and patience is key, lol. Edit: to answer your question I didn't do leak down as I don't have an air compressor... Link to comment Share on other sites More sharing options...
M4rked1 Posted July 6, 2016 Author Share Posted July 6, 2016 I retract my earlier statement, you are one of the few with a bad valve seat. Did you inspect the cylinders and pistons for wear or cracked ringlands? How do they look? Cylinders look good, Pistons look good for what I can see. I am not going to split the block as there are no signs of a problem . Link to comment Share on other sites More sharing options...
FJuan Posted July 6, 2016 Share Posted July 6, 2016 Sounds good, fingers crossed it's just a bad valve. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 7, 2016 Share Posted July 7, 2016 Answer to your question in post 16, yes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted July 7, 2016 Share Posted July 7, 2016 Answer to your question in post 16, yes. I saw that too, with the alignment of the cams being off. Then again, his crank gear was not in the proper position to determine exactly if the cams were off or not. There could be a possibility that the belt jumped a tooth if the crank gear was aligned. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
M4rked1 Posted July 7, 2016 Author Share Posted July 7, 2016 I was thinking maybe it jumped when I was removing the cam bolts. The more I thought about it , the less likely it seemed that it was like that when the car was together. Link to comment Share on other sites More sharing options...
