campoli Posted April 25, 2015 Share Posted April 25, 2015 So my car started to shutter when I come to a stop and my cel says maf so I replaced it w a new oem one car still shutters at stop I updated my map and still nothing anyone have any ideas? Link to comment Share on other sites More sharing options...
honduhunter Posted April 25, 2015 Share Posted April 25, 2015 mods? Link to comment Share on other sites More sharing options...
campoli Posted April 26, 2015 Author Share Posted April 26, 2015 Injen cai, hks bov, obx catless exhaust sti bp, v2 ap Link to comment Share on other sites More sharing options...
honduhunter Posted April 27, 2015 Share Posted April 27, 2015 are you tuned for that intake? Link to comment Share on other sites More sharing options...
campoli Posted April 28, 2015 Author Share Posted April 28, 2015 No just updated cobb map for there intake The car has been fine just started this recently Link to comment Share on other sites More sharing options...
Max Capacity Posted April 28, 2015 Share Posted April 28, 2015 Put the stock air intake back on. You don't need that other CAI. The stock one is good till about 400whp. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted April 28, 2015 Share Posted April 28, 2015 Have you checked all the vacuum hoses? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 28, 2015 Share Posted April 28, 2015 Maybe Tris can chime in here for more detail on this as he recently posted that the after market intakes can cause pre-detonation (read ring-land failure) because the MAF cannot properly read the volume of air being taken in by the intake. As was said above, put the stock intake back on as the AM intake provides no benefit unless you're pushing really high ponies. Link to comment Share on other sites More sharing options...
CloudSeed777 Posted April 28, 2015 Share Posted April 28, 2015 This thread: http://legacygt.com/forums/showthread.php/new-here-240081p2.html Link to comment Share on other sites More sharing options...
travrach Posted April 29, 2015 Share Posted April 29, 2015 Seeing how the car ran fine with those mods, what code did you really have? # please. Link to comment Share on other sites More sharing options...
campoli Posted May 1, 2015 Author Share Posted May 1, 2015 P0147 I think it said maf failure  It's gone now but my AP says it could be the 02, manifold gasket , or tmic gasket  I check all visible hoses for leak found none so I ordered everything the AP Said It Could Be  I have no stock parts to put back on all mods came on car when purchased last year I've replaced many parts since purchase all I want is for it to be done and reliable when it's running great it's an animal I'm just pampering it now till I get this issue solved even bought a beater to drive for now Link to comment Share on other sites More sharing options...
travrach Posted May 1, 2015 Share Posted May 1, 2015 P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3) If code comes back fix that 1st. Link to comment Share on other sites More sharing options...
campoli Posted May 3, 2015 Author Share Posted May 3, 2015 How do I fix it? Link to comment Share on other sites More sharing options...
travrach Posted May 4, 2015 Share Posted May 4, 2015 More then likely the sensor heater is bad, and you need a new one. But you should check the voltage at the sensor to make sure it has power to run the heater. Google test 02 sensor heater. Link to comment Share on other sites More sharing options...
campoli Posted May 9, 2015 Author Share Posted May 9, 2015 IM waiting on an up stream 02 Link to comment Share on other sites More sharing options...
