16psibrick Posted June 12, 2006 Share Posted June 12, 2006 after taking a week off to rest my aching back, i took it slow and just completed this install in a 2004 G35 coupe. the goals are: 1. superb, balanced sound quality 2. completely stealth install in the trunk 3. retain stock nav voice output and steering wheel controls so lets get started. in the past, i have used double din headunits in a G, and they have usually fit well with nary a problem... This time, since the car came with stock nav, we went ahead and got a good single din cd player. what i found out though, is that it takes a lot more work to properly install a single din in the G than a double din. the reason is that no one makes a pocket that fits below the headunit, and the opening is not a standard double din size. so...after a lot of work, i managed to get hte ehadunit, and modified a nissan pocket to fit in the new opening. the pocket was heavily trimmed to fit flush in the opening. a PAC-audio SWI-PS steering wheel adapter was installed to retain the stock steering wheel audio controls. http://simplicity.elitecaraudio.org/jaeg1.jpg http://simplicity.elitecaraudio.org/jaeg2.jpg next up is the front stage. to obtain the superb sound quality while taking up very little space, a DLS ultimate iridium 3 way component set up was used. the midrange and tweets are flushed into reinforced stock kick pieces, and there for takes up almost NO space. Note that on the driver side, a stock door psekaer is strapped belowt he dash, this speaker provides the stock NAV voice output. from almost all angles, this speaker is invisible http://simplicity.elitecaraudio.org/jaeg3.jpg http://simplicity.elitecaraudio.org/jaeg4.jpg the midbass were installed into the doors...in order to obtain the midbass responses needed, a fiberglass cut was installed and sealed into the door first, and then the speaker installed into it. this provides a semi-sealed enclosure in the door and provides superb midbass responses through out. note that new speaker wires are run into each door. http://simplicity.elitecaraudio.org/jaeg5.jpg http://simplicity.elitecaraudio.org/jaeg6.jpg http://simplicity.elitecaraudio.org/jaeg7.jpg http://simplicity.elitecaraudio.org/jaeg8.jpg Link to comment Share on other sites More sharing options...
16psibrick Posted June 12, 2006 Author Share Posted June 12, 2006 moving on to the trunk. again, this is a full stealth install, so here is the view with the trunk open. pretty much no change from stock and completley usable. http://simplicity.elitecaraudio.org/jaeg9.jpg http://simplicity.elitecaraudio.org/jaeg10.jpg and now here is the system installed below it a vinyl trim panel showcases dual elemental 11kv.2 subwoofers, a DLS refernece series RA50 5 channel amp, and the four crossovers that the iridium 3 way set comes with. the effect is clean and classy http://simplicity.elitecaraudio.org/jaeg11.jpg http://simplicity.elitecaraudio.org/jaeg12.jpg http://simplicity.elitecaraudio.org/jaeg13.jpg Link to comment Share on other sites More sharing options...
16psibrick Posted June 12, 2006 Author Share Posted June 12, 2006 of course you are probably wondering how the carpet can sit on the sub without hitting it, well the solution is simple, the stock plastic covering piece that went over the spare tire well was used as a spacer, with the area around the subs cutout and mesh grilled, simple and effective venter spacer and protects the subs http://simplicity.elitecaraudio.org/jaeg14.jpg and now the shot of the wires beneath the cover to show that there arent flying wires all ovet the place http://simplicity.elitecaraudio.org/jaeg15.jpg[/img Link to comment Share on other sites More sharing options...
NutBucket Posted June 12, 2006 Share Posted June 12, 2006 of course you are probably wondering how the carpet can sit on the sub without hitting it, well the solution is simple, the stock plastic covering piece that went over the spare tire well was used as a spacer, with the area around the subs cutout and mesh grilled, simple and effective venter spacer and protects the subs http://simplicity.elitecaraudio.org/jaeg14.jpg and now the shot of the wires beneath the cover to show that there arent flying wires all ovet the place http://simplicity.elitecaraudio.org/jaeg15.jpg Link to comment Share on other sites More sharing options...
jim malach Posted June 12, 2006 Share Posted June 12, 2006 clean work. Link to comment Share on other sites More sharing options...
jim malach Posted June 12, 2006 Share Posted June 12, 2006 not a fan of the kick pieces. Link to comment Share on other sites More sharing options...
hondas123 Posted June 12, 2006 Share Posted June 12, 2006 Great job....wish I had that type of talent. Thanks for sharing the pics. - The Mortgage Man Link to comment Share on other sites More sharing options...
axis008 Posted June 12, 2006 Share Posted June 12, 2006 Very clean work. -ben Link to comment Share on other sites More sharing options...
VXCL Posted June 12, 2006 Share Posted June 12, 2006 clean. nice work! MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
dr. pepper Posted June 13, 2006 Share Posted June 13, 2006 where can i get work like yours done to my gt in Mass. or NH, and how much does a clean setup like this run for? Link to comment Share on other sites More sharing options...
Precise Posted June 13, 2006 Share Posted June 13, 2006 man, you west coast guys are really good...wish we had car nuts like you in the east Link to comment Share on other sites More sharing options...
16psibrick Posted June 13, 2006 Author Share Posted June 13, 2006 nah, i was in pittsburgh, PA for 10 years 3 of whcih i did cars, but we had all the poor people with no money for systems dr.pepper, look no further than nazar at wickedcas in NJ for your install www.wickedcas.com he is the one doing the side boxes for the lgt sedans b Link to comment Share on other sites More sharing options...
16psibrick Posted June 13, 2006 Author Share Posted June 13, 2006 this set up including everyhing: meaning: amp, subs, speakers, headunit, wiring, the double din conversion kit (350+ bucks), kicks, door pods, nav tap, steering wheel controls, and all other labor and material charges, through me is about mid to low 4000 dollar range. from a good normal shop about 5-6000 would be about right b Link to comment Share on other sites More sharing options...
msmith Posted June 13, 2006 Share Posted June 13, 2006 I like your style, 16psi... beautiful work. Link to comment Share on other sites More sharing options...
16psibrick Posted June 13, 2006 Author Share Posted June 13, 2006 thanks manville, coming from you it means a lot Link to comment Share on other sites More sharing options...
98quiksilvergt Posted July 17, 2010 Share Posted July 17, 2010 Very nice!!! I did a system like that In my thunderbird sc. It takes alot of time!! Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 18, 2010 Share Posted July 18, 2010 I'm not a fan of single-din headunits. Probably because they just don't look OEM, and thats what I prefer. The trunk install is super clean though! If you loaded a few golf bags in the back, would you dent the mesh and hit one of the subs? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
OutbackXT05 Posted August 7, 2010 Share Posted August 7, 2010 That looks sexy wish my mom would let me do this with her G35. Though i could never do anything that clean, my audio installs are simple and simply put crazy loud Link to comment Share on other sites More sharing options...
