sjxbrd Posted May 24, 2015 Share Posted May 24, 2015 Recently purchased a used P-206 head unit from a member of this board to replace the P-203 in my 06 LGT wagon. The CD changer seems to be acting up on this HU. When I press load, there is no change to the display, and the CD changer does not do anything; on the P-203, it would show CD in, and I can hear the CD changer going through the loading sequence. I have tried disconnecting the head unit from the car for 20 minutes to let everything reset, that did not help. I have verified that the load button works by metering the contacts behind the physical button. Any suggestions:confused: Link to comment Share on other sites More sharing options...
starionesir Posted May 28, 2015 Share Posted May 28, 2015 I have heard the changers are easily damaged if miss handled while shipping. Did you contact the member here to check the condition of the changer? Link to comment Share on other sites More sharing options...
eljefe1981 Posted May 29, 2015 Share Posted May 29, 2015 The HU might be locked. It might need a code to unlock all the functions. Can you control everything else? Link to comment Share on other sites More sharing options...
