Fisch Posted June 11, 2011 Share Posted June 11, 2011 I have a 05 LGT, and I recently noticed a shimmy in my steering wheel when driving 55-80 mph, I immediately thought it was a balance issue. I had NTB balance all four of my wheels and I got an alignment done, just to be safe. The problem lessened slightly, So I took it back about a week later to get it re-balanced. One of their employees told me that he double checked the balance job and that 2 of my wheels seem to be bent. I don't recall hitting anything (potholes) with excessive force. I do live in Pennsylvania, though, so 2 wheels just bending out of nowhere could be possible. The shimmy in my wheel is almost gone, but I can still notice it somewhat at higher speeds. My question to all of you is: 1. Should I spend the 120 dollars per wheel and replace both of them? 2. Should I try and find a shop to see if they can be fixed (if it is possible)? Thanks all Link to comment Share on other sites More sharing options...
HCF Posted June 11, 2011 Share Posted June 11, 2011 Personally, I would move the 2 suspected "bent" wheels to the rear, and see if the steering wheel smooths out. This does 2 things.. - gives you time to make the decision you posted - confirms that it is infact an issue with the wheels, and not a early development of a bearing issue, which these cars are very well known for. Link to comment Share on other sites More sharing options...
Fisch Posted June 11, 2011 Author Share Posted June 11, 2011 I didn't know bad wheel bearings could cause that issue. Is there any other signs of wheel bearings need replacing? I'll try your suggestion tomorrow morning seeing as I work all night, and I'll keep you posted. Also wanted to put in that my tires aren't losing any air, and I heard that if your wheel is bent the tire will slowly leak. I don't know how accurate that is, though. Link to comment Share on other sites More sharing options...
