don7 Posted May 30, 2014 Share Posted May 30, 2014 Its nothing life changing or anything but if you push your mileage reset button on your gauge cluster it will light up your odometer and turn your gas gauge on to see your fuel level without needing your key in the ignition. Link to comment Share on other sites More sharing options...
Redryan98 Posted May 30, 2014 Share Posted May 30, 2014 I didn't know that. Thanks for sharing! (that is most definitely life changing:) Link to comment Share on other sites More sharing options...
iyalla Posted May 30, 2014 Share Posted May 30, 2014 Nice Link to comment Share on other sites More sharing options...
yardie Posted May 30, 2014 Share Posted May 30, 2014 I just found out that I can still up and down shift via paddle shifter found on the '08-09 LGT while the selector is still in Drive. Link to comment Share on other sites More sharing options...
heiche Posted May 30, 2014 Share Posted May 30, 2014 Had to go outside to try the odo button trick for miles and gas level. Best. Feature. Ever BtSsm - Android app/Bluetooth adapter. LV, logging, gauges and more. For 05-14 Legacy (GT, 2.5, 3.0, 3.6), 02-14 WRX, 04-14 STi, 04-14 FXT, 05-09 OBXT Link to comment Share on other sites More sharing options...
PearlBlueGT Posted May 30, 2014 Share Posted May 30, 2014 I just found out that I can still up and down shift via paddle shifter found on the '08-09 LGT while the selector is still in Drive. Can this be done on 05GT? Link to comment Share on other sites More sharing options...
covertrussian Posted May 30, 2014 Share Posted May 30, 2014 I love how Subaru added that useless feature but refused to add the ability to raise your windows after you turn off your car, my 00 Infiniti can do that... 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Captslow Posted May 30, 2014 Share Posted May 30, 2014 Works in my 05 Wagon. I also noticed you can eject disc's and check the time all without the key. Link to comment Share on other sites More sharing options...
yardie Posted May 30, 2014 Share Posted May 30, 2014 I just found out that I can still up and down shift via paddle shifter found on the '08-09 LGT while the selector is still in Drive. Can this be done on 05GT? Not sure, do the '05-07 USDM LGT's come with steering wheel mounted button shifters? Link to comment Share on other sites More sharing options...
Captslow Posted May 30, 2014 Share Posted May 30, 2014 Yep, That too My wagon is an 05 and if tap down it downshifts with out being in sport mode. Link to comment Share on other sites More sharing options...
firehawk618 Posted May 31, 2014 Share Posted May 31, 2014 I love how Subaru added that useless feature but refused to add the ability to raise your windows after you turn off your car Agreed! Hell, even make the windows work in accessory. Sheesh. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 31, 2014 Share Posted May 31, 2014 Cool find. Owned the car since 2004 and never knew this. Link to comment Share on other sites More sharing options...
SilverLegs Posted May 31, 2014 Share Posted May 31, 2014 I did not know this!!!! I'm so glad I'm surfing the forums today! Link to comment Share on other sites More sharing options...
micha3lchu Posted May 31, 2014 Share Posted May 31, 2014 very cool info! Very glad you shared. I had no idea. Link to comment Share on other sites More sharing options...
KRM Posted June 1, 2014 Share Posted June 1, 2014 Found this out in 07 when it was the stealership checking my miles for warranty. It is a neat little feature to have Link to comment Share on other sites More sharing options...
dasColbert Posted June 1, 2014 Share Posted June 1, 2014 Totes life changing. Link to comment Share on other sites More sharing options...
SilverLegs Posted June 3, 2014 Share Posted June 3, 2014 Found this out in 07 when it was the stealership checking my miles for warranty. It is a neat little feature to have Totally off topic but your Username is what my Initials were before I got married. :-) now they are KRF. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
theflystyle Posted June 3, 2014 Share Posted June 3, 2014 This is why all cars need to be able to be wirelessly updated from the manufacturer.... Tesla does it but I would hate to come down to the car one morning to find that something new that I may not like. Link to comment Share on other sites More sharing options...
bluesuby Posted June 3, 2014 Share Posted June 3, 2014 Sounds useful for mileage recording after an oil change. Thank you. Link to comment Share on other sites More sharing options...
RallyMachine Posted June 5, 2014 Share Posted June 5, 2014 I tried this today and it's awesome! I do have a question though: If you keep pressing the the button, after "Trip B" I get a message that says "S - ON" (or 5, I can't really tell) and then if you press it again you get "1 - ON". Both of these can be turned off by holding the button when they are selected. Any idea what these do when switched off? Edit: Nevermind, I just found it in the manual: "S - ON/OFF" Controls the gauge sweep motion when the keys are put in the ignition and "I - ON/OFF" controls the illumination sequence during the same time. MOAR EASTER EGGSSS Link to comment Share on other sites More sharing options...
STi_mulation Posted June 6, 2014 Share Posted June 6, 2014 eureka..!!! Link to comment Share on other sites More sharing options...
