lgt6969 Posted May 11, 2012 Share Posted May 11, 2012 My car has been idling very roughly lately. The engine shakes and the roughness on cylinder 2 on my Accessport has read up to 24. All the spark plugs were changed and I switched the coil pack on cylinder 2 with cylinder 1 and the misfire did not follow. There is oil consumption but it has been there since I purchased the car. The only thing I have not checked are the injectors. Link to comment Share on other sites More sharing options...
Dcb122580 Posted May 11, 2012 Share Posted May 11, 2012 You should do compression and cylinder leak down tests. Link to comment Share on other sites More sharing options...
m sprank Posted May 11, 2012 Share Posted May 11, 2012 Move the injector too. A compression test is all that needed if a ringland is bad. Link to comment Share on other sites More sharing options...
Lardo420 Posted May 11, 2012 Share Posted May 11, 2012 does your car smoke on startup? Link to comment Share on other sites More sharing options...
lgt6969 Posted May 11, 2012 Author Share Posted May 11, 2012 My car doesnt smoke on start up but it has been running very rich lately causing the exhaust tips to become blacker than usual. To add to the symptoms, I did smell something electronic burning on my way home a few days ago while I was stopped at a red light. I still havnt gotten a check engine light from the misfires. I went and bought a compression tester and cylinder 2 came to 110 on the first try then 90 for 3 times in a row after that. cylinder 1 was about 120. I didnt check the cylinders in the rear yet. Link to comment Share on other sites More sharing options...
Lardo420 Posted May 11, 2012 Share Posted May 11, 2012 did you hear a pop while doing the compression test? sometimes the seal breaks during the test Link to comment Share on other sites More sharing options...
lgt6969 Posted May 11, 2012 Author Share Posted May 11, 2012 i didnt hear any pops Link to comment Share on other sites More sharing options...
SSpeed Posted May 11, 2012 Share Posted May 11, 2012 My car doesnt smoke on start up but it has been running very rich lately causing the exhaust tips to become blacker than usual. To add to the symptoms, I did smell something electronic burning on my way home a few days ago while I was stopped at a red light. I still havnt gotten a check engine light from the misfires. I went and bought a compression tester and cylinder 2 came to 110 on the first try then 90 for 3 times in a row after that. cylinder 1 was about 120. I didnt check the cylinders in the rear yet. Check that your rear O2 sensor wire isn't getting burned on the downpipe.... Link to comment Share on other sites More sharing options...
m sprank Posted May 11, 2012 Share Posted May 11, 2012 Is the TB held wide open wile running the compression check? It needs to be. Also need number on all 4. 120 is not that bad. 110 is getting low. If 120 on 3 of them and 110 on 1 you are ok. If you actually have a cylinder at 90, it is bad. Link to comment Share on other sites More sharing options...
SSpeed Posted May 11, 2012 Share Posted May 11, 2012 Also, where are you at? If you are at any sort of altitude it will significantly lower your compression test numbers.... Link to comment Share on other sites More sharing options...
OutbackXT05 Posted May 13, 2012 Share Posted May 13, 2012 I had rough idle too. Did a compression test and mine was 131-129 on 1,2,3 and on #4 it was 50. The odd part was my number 2 walls were lightly scored and the ringland had completely broke 1/3 of the diamater of the piston but not compression lost. Link to comment Share on other sites More sharing options...
suds2250 Posted May 13, 2012 Share Posted May 13, 2012 ^^^that's crazy! v What was #4 like? 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
AZP Installs Posted May 13, 2012 Share Posted May 13, 2012 I had rough idle too. Did a compression test and mine was 131-129 on 1,2,3 and on #4 it was 50. The odd part was my number 2 walls were lightly scored and the ringland had completely broke 1/3 of the diamater of the piston but not compression lost. We have seen this on a few occasions. -mike http://www.pbase.com/paisan/image/91072632.jpghttp://www.pbase.com/paisan/image/141039922.jpg http://www.pbase.com/paisan/image/133406601.jpg http://upload.pbase.com/image/137566671.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. AIM: AZP Installs | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.2971 | T-1 Certified Amsoil Direct Jobber "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
OutbackXT05 Posted May 13, 2012 Share Posted May 13, 2012 ^^^that's crazy! v What was #4 like? #4 had 6-7 cracks on it. It was all still together but there were too many cracks on it to hold compression unlike the number 2. Link to comment Share on other sites More sharing options...
VermontGT Posted May 13, 2012 Share Posted May 13, 2012 Take heart, young Jedi! My misfire and low compression (90 psi cyl 4) turned out to be a burnt intake valve. It could only be pretty expensive to fix vs. extremely so. Link to comment Share on other sites More sharing options...
