mazdaaspec Posted February 24, 2010 Share Posted February 24, 2010 I have these XXR rims wrapped with BFgoodrich GForce T/A which are 255/35/18 with a 48 offset. Do I even think of putting these on or just sell them? I am affraid that this big of a tire will cause problems under the wheel well. any suggestions?http://hphotos-snc3.fbcdn.net/hs151.snc3/17840_337135939609_510674609_4767366_5583095_n.jpg http://hphotos-snc3.fbcdn.net/hs151.snc3/17840_337135924609_510674609_4767365_1167832_n.jpg http://photos-h.ak.fbcdn.net/hphotos-ak-snc3/hs151.snc3/17840_337135959609_510674609_4767367_347723_n.jpg Link to comment Share on other sites More sharing options...
JonLGT Posted February 24, 2010 Share Posted February 24, 2010 What suspension are you running or planning on running? Link to comment Share on other sites More sharing options...
quick4dr Posted February 26, 2010 Share Posted February 26, 2010 just start rolling your fenders, pull them too i guess, and check your camber. nice tires though! rims are cool too Link to comment Share on other sites More sharing options...
DrCloud Posted February 26, 2010 Share Posted February 26, 2010 On my 08 LGT Spec B, 245/40-18s on ET48 (8" wide) wheels rubbed at stock suspension height. The 255/35s are not quite so tall, but the extra width may get you. HPH Link to comment Share on other sites More sharing options...
Xenonk Posted February 26, 2010 Share Posted February 26, 2010 it wont hurt to just put them on, drive down the street and back. I've done 255/35/18 Toyo T1-S on a 18x8 +51 wheel using Zeal V6 coilovers lowered 2.25" or so with about -2 degrees camber up front and -1.75 degrees camber in the rear.. just have to roll the fenders.. I could have put on some 265/35/18 with a +10mm offset spacer and it would have been fine.. Keefe Link to comment Share on other sites More sharing options...
Xenonk Posted February 26, 2010 Share Posted February 26, 2010 On my 08 LGT Spec B, 245/40-18s on ET48 (8" wide) wheels rubbed at stock suspension height. The 255/35s are not quite so tall, but the extra width may get you. HPHÂ Spec B stock shocks have about 1" taller/higher spring perch than the GT. That's why you can cram as tall as a 26" tall tire on the Spec B, but not on the GTs stock suspension.. I think the most you can fit is a 25.4" tall tire to clear the GT spring perches. Keefe Link to comment Share on other sites More sharing options...
MyWifezLEGi Posted February 26, 2010 Share Posted February 26, 2010 It will clear the stock suspension , I tried fitting 18*9 +43 w/ 255/35/18 and the rears need to be rolled Link to comment Share on other sites More sharing options...
Xenonk Posted February 26, 2010 Share Posted February 26, 2010 is that on your 2.5i or OB?? Cuz OBs have a lot of clearance.. you can run as tall as a 27.2" or 27.3" tall tire. Keefe Link to comment Share on other sites More sharing options...
mazdaaspec Posted February 26, 2010 Author Share Posted February 26, 2010 I have a 2.5i legacy and will be getting Megan Racing Suspension. Feel in love with them after I put them on my crx. Just using it to help the rims out. It will have the adjustable damping in the front and rear and adjustable camber in the front. should I get something for the rear end to adjust the suspension in the rear Link to comment Share on other sites More sharing options...
Xenonk Posted February 27, 2010 Share Posted February 27, 2010 you'll just need to roll the fenders a lot and make sure you get a fairly aggressive alignment with the camber to make them clear the suspension stroke or you'll end up rubbing.. Keefe Link to comment Share on other sites More sharing options...
JonLGT Posted February 28, 2010 Share Posted February 28, 2010 Let me know if you decide to sell those tires though. Link to comment Share on other sites More sharing options...
mazdaaspec Posted March 1, 2010 Author Share Posted March 1, 2010 gesh JonGT lol. if it doesnt work out I will sell the tires on the rims. but let me get the suspension here first. Ordering it on the 2nd. Link to comment Share on other sites More sharing options...
wpgspecb Posted May 9, 2010 Share Posted May 9, 2010 18x8.5 or 9 wide, at +43 with 255/35 fit with only rolling ? Link to comment Share on other sites More sharing options...
mazdaaspec Posted May 10, 2010 Author Share Posted May 10, 2010 the are 18x8.5 at +48 with 255/35. I only needed to roll the rear fenders and that was all. My fronts do not rub at all with these on. yes the car is ?noticablely? lower but not much. Link to comment Share on other sites More sharing options...
bama16 Posted May 15, 2010 Share Posted May 15, 2010 you'll have to watch left hand turns with dips at any speed other than crawling. it'll push the wheel up into wheel well while turned and the tire will grab the fender lip and pull it down...and then start slicing up the tire. Link to comment Share on other sites More sharing options...
mazdaaspec Posted May 16, 2010 Author Share Posted May 16, 2010 I have not had that problem. I do drive it like a grandma tho. I live in ND and roads are.... missing. HA HA HA no but Massive craters fill our streets after the winter and never get fixed. Link to comment Share on other sites More sharing options...
