XXR Thread
subiebeast22
Throw a pic of your car up. Lots of ppl on here are good at photo shopping wheels on. I think Mookz can do it
Easier still just take a side on photo of ya car then go to http://www.vrimz.com they have a virtual mag simulator with hundreds of rims to choose from (only downside is the lite version doesn't have a huge selection)
  • 2 weeks later...
Go 18's. 17's look small on our cars. I have 18x 8.75 and I'm going to be using a 225/40/18 tire nothing to aggressive and I'm on stick bilsteins.
What offset on the 18x8.75's, and will 245's fit in the wheel well with those rims. I am also stock Spec.B suspension.
FYI, the Hankook Ventus V12 Evo 245/40-R18 are the same exact height as the factory Spec.b Tire
The offset on the 18x8.75's is a +35.
I really like these! Think I'm going to buy some. Think they'll fit stock 07 LGT suspension and brakes without rubbing? I know the LGT has a little less ground clearance than the Spec B. Just want to make sure before I order them, thanks!
Subiebeast22...
I'm curious to see if you'll have to do much fender work with those. I've been looking at 8.75-9" wide wheels in a similar offset and want to avoid pulling if possible...but I do plan to be much lower than where you're sitting...
^^Yeah your definitly going to need fender work. It will be nearly impossible to fit that witdth/offset especially if your low. I'm still rubbing a lot but mostly on big bumps. I did run a 225 tires so there is the slightest amount of stretch which I would guess helps with rubbing issues. I'm hoping I can get away with just a roll while I'm on stock suspension. I'll let you know what i have to end up getting done as soon as I can get it done. I'm hoping for no pill either.
Yeah you will definitly clear your brakes. Dont quote me but I think these will clear brembos. When I'm just driving regular I don't rub unless there is a pretty good bump. Idk how roads are in Wisconsin but in the northeast they suck. You will probably rub a lot if the LGT suspension is lower but they physically will fit. I can't have anybody in my back seat right now and I'm hoping to get a roll soon
I'm so glad I got new wheels....527s started popping up all over the place after I got them a little over a year ago. I understand why though....they are cheap and look nice.
http://i234.photobucket.com/albums/ee192/SubieChik/B6B5FE6F-8395-476B-9C07-7B90FC706FCC-7070-00000337C14D9638.jpg
http://i234.photobucket.com/albums/ee192/SubieChik/6971171521_d1640f7ac2_b.jpg
http://i234.photobucket.com/albums/ee192/SubieChik/Steve%20Nguyen%20Shoot/258674_510008125695491_507833450_o.jpg
