haycock Posted December 27, 2011 Share Posted December 27, 2011 So im installing a up and dp on my wifes 05lgt today and i noticed when i pulled the stock dp off that the door on the wg seemed to be off center of the hole and had about a .250" gap. the side of the door is also rubbing the housing making it kinda sticky when i move it by hand. there is a sleeve that looks to be pressed in the housing that the shaft turns in, i wonder if i can just press the sleave back in a bit... at any rate this doesnt seem right to me so i thought i would ask for your opinions. thanks Link to comment Share on other sites More sharing options...
GTTuner Posted December 27, 2011 Share Posted December 27, 2011 I see this often, you may be able to push the bushing back in but be careful you do not make the WG flapper stick. I would disconnect the WG actuator and once your done be sure the flapper moves freely. Link to comment Share on other sites More sharing options...
bmx045 Posted December 28, 2011 Share Posted December 28, 2011 drill out the pin and insert a new one Link to comment Share on other sites More sharing options...
