Bannonjr Posted April 22, 2011 Share Posted April 22, 2011 98 Legacy L wagon 2.2 awd My bearing blew, so I'm trying to replace it, I bought a new hub assembly, but when I yanked it out..actually, I barely had to tug on it, it came out but seems the new is different from the old. There seems to be more bearings inside as you can see from the pics. As I looked and searched, it says to remove the "entire hub assembly" with 3-4 14mm bolts, but I don't got em..what am I missing? http://i369.photobucket.com/albums/oo138/Bannonjr/mobile%20uploads/IMG-20110422-00563-1.jpg http://i369.photobucket.com/albums/oo138/Bannonjr/mobile%20uploads/IMG-20110422-00564-1.jpg http://i369.photobucket.com/albums/oo138/Bannonjr/mobile%20uploads/IMG-20110422-00565-1.jpg Link to comment Share on other sites More sharing options...
Bannonjr Posted April 22, 2011 Author Share Posted April 22, 2011 Do I have to take the knuckle off, press out that bearing...etc? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted April 23, 2011 I Donated Share Posted April 23, 2011 The whole knuckle has to come off the car and the bearing inside of it has to be pressed out and a new one pressed back in. Then use the press to press the hub (piece with the lug nuts) into the bearing -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Bannonjr Posted April 23, 2011 Author Share Posted April 23, 2011 Gotcha ok tks So outside in, llooks like Hib, outer seal, bearing, c clip, inner seal Yes? Hard to tell since its all busted My tone ring also bit the dust Link to comment Share on other sites More sharing options...
cpundyk Posted April 23, 2011 Share Posted April 23, 2011 thanks! Link to comment Share on other sites More sharing options...
johnegg Posted April 23, 2011 Share Posted April 23, 2011 go to a local salvage yard and get a replacement knuckle. cheaper and easier than rplacin g the bearing a tone ring. then when that bearing fails replace it. Link to comment Share on other sites More sharing options...
Bannonjr Posted April 23, 2011 Author Share Posted April 23, 2011 I already bought everything...well, hopefully everything but the tone ring..wasn't very expensive plus I can learn something new. Got a new ball joint and a tie rod end while I was at it. Link to comment Share on other sites More sharing options...
