jvit10 Posted January 6, 2012 Share Posted January 6, 2012 I am looking to install a manual boost controller for my car, with a boost gauge and pod in the middle console above the stereo, or on the A pillar, I am not looking to spend more than 200$ on the three parts(IF POSSIBLE), does anyone have suggestions for me please! Link to comment Share on other sites More sharing options...
scoobyscoodle Posted January 6, 2012 Share Posted January 6, 2012 http://cdn.styleforum.net/8/85/851ac22e_d61912a9_cant-tell-if-serious.jpeg Link to comment Share on other sites More sharing options...
Drift Motion Posted January 6, 2012 Share Posted January 6, 2012 GL with that budget Link to comment Share on other sites More sharing options...
stickshift4life Posted January 6, 2012 Share Posted January 6, 2012 drift motion im sure you helped the guy out tons with that post Link to comment Share on other sites More sharing options...
Nrw Posted January 6, 2012 Share Posted January 6, 2012 IBblownmotor Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 I hope the op atleast replies Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 im willing to spend more, nobody helped so why even bother posting you tools Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 because you clearly have no idea and need to learn a bit more about how these ecu's work before adjusting boost manually. Link to comment Share on other sites More sharing options...
Nrw Posted January 6, 2012 Share Posted January 6, 2012 quick google search http://www.jcspods.com/subarugt.html those take any 52mm pods, as the site lists. Link to comment Share on other sites More sharing options...
angeltalin Posted January 6, 2012 Share Posted January 6, 2012 most people with legacys atleast on this forum use elec boost control selenoids, easier for tuners less hassle for the driver. Grimmspeed is probably the most popular you can get one for about 95 bucks. if your going boost gauge, on a budget ; ebay, otherwise prosport,stri,defi or too much for you StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 thank you, that was simple, i just wanted to make sure my research wasn't too far off, no thanks to the first couple posts Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 i have a mechanic who works on subarus helping me and wacthing over me with tuning the boost gauge thanks alot for the negative feedback on everything bmx, your comments arent needed, go on facebook or something Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 any time Link to comment Share on other sites More sharing options...
Lardo420 Posted January 6, 2012 Share Posted January 6, 2012 OP how does one tune a boost gauge Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 im sorry its real complicated, you adjust it until the boost isnt to high, its pretty simple and its cost effective instead of buying an electric one Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 so you adjust the boost gauge to your max boost? interesting. Link to comment Share on other sites More sharing options...
Lardo420 Posted January 6, 2012 Share Posted January 6, 2012 are you turning up the manual boost controller and looking at the gauge to see what the boost is? sry you confuse me bra Link to comment Share on other sites More sharing options...
Nrw Posted January 6, 2012 Share Posted January 6, 2012 http://gallery.nekito.net/albums/album05/Anya_Popcorn.gif Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 ok i dunno what the hell im talking about lol, its obvious, so subaru genious men and woman, lead me in the right direction, no more wasting time haha Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 my boy said he would put it in so id figure id ask, obviously it was a bad idea cause instead ofhelp im getting abused verbally lol Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 ok, on a serious note. have a boost controller in your interior is pointless and useless. you go to a tuner and he adjusts boost with timing, fuel, etc. once its tuned to optimal boost level, it STAYS there, you DO NOT adjust it yourself since the tune equates a boost level with an amount of fuel and timing. adjusting boost once those are set is adding air/pressure to a set fuel (injector latency), and significantly throws off AFR. thus upping the boost after tuned will cause severe lean conditions, with detonation and knock, and a lot of heat, and a lot of damage. boost controllers stay in the engine compartment and are not to be adjusted by the driver, only by the tuner. EBCS's are the way to go, not manual controller. http://www.grimmspeed.com/catalog/product_info.php?cPath=151&products_id=145 you only need an aftermarket boost controller if your stage 2 or higher, the stock bcs handles up to 19psi decently. if you're stage 2 fmic then an ebcs is a good idea for boost building response. if you are stock, there is no benefit really to an aftermarket controller. Link to comment Share on other sites More sharing options...
jvit10 Posted January 6, 2012 Author Share Posted January 6, 2012 so what you guys suggest since manual is not a good idea, y electric, and whats a good brand Link to comment Share on other sites More sharing options...
Lardo420 Posted January 6, 2012 Share Posted January 6, 2012 grimmspeed ebcs Link to comment Share on other sites More sharing options...
bmx045 Posted January 6, 2012 Share Posted January 6, 2012 hello? i provided you with a link. a manual BCS is a thing of the past. Link to comment Share on other sites More sharing options...
Nrw Posted January 6, 2012 Share Posted January 6, 2012 hello? i provided you with a link. a manual BCS is a thing of the past. tl;dr Link to comment Share on other sites More sharing options...
